Blizzak tire pressure?
Discussion in 'Modifications And Maintenance' started by xodad2, Nov 28, 2013.
  1. xodad2
    xodad2 Well-Known Member
    I'm currently running my blizzaks @35 psi. Just wondering what everybody else runs theirs at.
  2. WLGT
    WLGT Well-Known Member
    38F/36R
  3. xodad2
    Why the different pressures?
  4. JasonoJordan
    I'd think that would wear on your center diff.
  5. boone1186
    boone1186 Active Member
  6. Shane86
    Shane86 Well-Known Member
    36psi all around.
  7. pillboy
    I'm pretty sure my Legacy also states on the placard a 2 PSI higher pressure in front (more weight over the front wheels than the rear).
  8. Shane86
    a pressure difference will create a difference in handling. Higher pressure in the front will generally yield more understeer.
    Squaring up the pressures (bringing the rear up to the front) will make the rear end a bit more lively. not a ton in a 2psi difference, but it's there.
  9. TMF
    I was just wondering about snow tire pressures and I was thinking it would almost make sense to run them at a relatively lower tire pressure to aid with traction...at the expense of gas mileage and responsiveness. Perhaps due to the compound and design of snow tires, a lower pressure isn't necessary?
  10. Shane86
    I favor a standard pressure as they're already softer than normal tires, and I like to go sideways... Don't wasn't to soften that up and peel one off the bead.
    If I get in a bad situation it's easy enough to bleed down.
  11. phi11
    All three of our legacys have a 2psi difference from front to back.
    (based on the door omgstickers)
    '98 GT BD, '07 OB BP
  12. TMF
    True, I was thinking like keeping them at the recommended pressures (32psi or so), which is relatively lower than what I normally run my tires at even on the DD (usually 36ish). I will perhaps need to do some experimentation!
