GSC Power Division Releases Intake/Exhaust Valves
Discussion in 'Vendor Announcements/Sales/Discounts' started by maperformance, May 1, 2012.
  1. Offline
    maperformance Vendor
    Aug 27, 2006
    Message Count:
    1,192
    [IMG]
    When creating there new valve line GSC set out to create the best performance longest lasting valves available to the aftermarket. Using advanced 3D design and simulation programs they have created a stronger and higher flowing valve head design. They flow test prototype valve heads in the specific applications to make sure we have the highest flowing valve head available on the market today. With the materials used GSC has less valve distortion at the face than any of the tested designs. Less distortion allows or better sealing under extreme conditions and more consistent performance threw the life of the valve. GSC Power-Division's new valves are sure to become the industries standard for sport compact performance valves.
    Valve Features
    Swirl polished heads for smoother air flow over the valve
    Back cut to reduce valve weight for higher rpm, higher boost pressure and allow for more aggressive cam profiles without increasing valve spring seat pressures.
    Valve stems are micropolished to allow for less oil retention on the stem which creates less drag on the stem to guide for a smoother motion.
    Fully nitrated ( this includes the 45 which increases valve life and makes a better seal at the valve seat for improved cylinder pressure) also reduces carbon buildup on the backside of the valve.
    Intake valves are a modified 21-4n stainless and Exhausts are a modified 23-8n stainless material for high heat capacity while maintaining longevity.
    Valve tips are either hardened or have a stelite wafer tip fused so that the tip is within 5 Rockwell C of the rocker or valve tappet for extended life and less wear
    Valve tips. We have taken extra time to adjust tip heights on the applications to require less tipping of the valve to maintain proper tip height for proper valve train geometry, and to cut down on install times when setting valve lash.
    We have also adjusted the Keeper grove to properly balance intake and exhaust spring pressures to reduce the use of valve spring shims and maximize performance from our spring and retainer kits.
    Valves will work with an oem keeper/lock or when available our upgrade keeper/lock. It's not mandatory but it is suggested that any valve lock not be reused on performance applications do to material grooving.
    http://www.maperformance.com/subaru-02-07-wrx-engine-components-valvetrain-components-valves/
Share This Page
