Help Needed. Front Strut Bolts.
Discussion in 'Modifications And Maintenance' started by Fienix, May 9, 2013.
  1. Fienix
    Fienix Well-Known Member
    I'll pay $20 to the person that breaks these 4 (2 per side) bolts free. I've broken sockets, tried impact wrench, PB blaster, WD 40 and 345ft/lbs. breaker bar to no avail.
    Catch: You have to bring me to the hardware store if you break the bolts.
    An extra $20 if you help me install the 2 sets of struts/springs afterwards.
    I'm in Bloomington and available anytime on Saturday. Can come to your garage if its not too far..
  2. phi11
    I eat bolts like that for breakfast.
    Throw some heat at them.
  3. Fienix
    That's the only thing I haven't tried yet. Might have to invest in a torch...
  4. Mr.Tran
    Mr.Tran Well-Known Member
    Definitely. As far back as I can remember, if it wasn't drilled out heat got it out.
  5. phi11
    Now I recall myself cutting one of these off, and pressing it out.
    That was a long night.
  6. Shancaldazar
    Why I am so tempted....
  7. Ntxhuav_Khang
    strange how you're having problems with these bolts. Put your back into it...lol. Also try turning the bolt/nut the right way to loosen. lol
    where you at anyways? j/c
  8. idget
    You can get a torch from sears for less than the $20 you're offering.
  9. bubba_crx
    bubba_crx Well-Known Member
    Best penetrant is 1/2 ATF 1/2 acetone mixed in an oil can. Used it on my rears once, just let it soak for a while
  10. Fienix
    I break things putting my back into it lol
    Ntxhuav_Khang likes this.
  11. Terry Ammerman
    Propane torch won't do it.
  12. idget
    1) yes it will.
    2) mapp gas is also available
  13. CLee89
    CLee89 Member
    I'll brake those bolts for you for $20. pm me, we'll talk.
  14. TMF
    Fair warning - be aware of the brake line and abs cable and be sure to keep the heat away! Either hold them out of the way or use aluminum foil or something to block some of the heat.
    Also, the crappy torches from Wal-Mart are just that...crappy. It's worth buying the slightly nicer version that is at Sears and other places. The nicer torches hold a much stronger flame.
    I just had the same issue on my Saabaru, except I got the nuts off but couldn't get the bolts out. Torched it up and they came right out. Talk about a sense of accomplishment after that! :D
  15. Fienix
    So the Mapp torch was the ticket. Heated the nut up for a minute or two and it came off with ease. Thanks guys!
    ejholmgren, BroCo and phi11 like this.
