Got a huge amount of parts in the shop and am ready to part ways with many of them. I am open to offers, but be reasonable; please, save us both the time. Prices are all fair in my opinion - but I'm a reasonable guy so just ask. There WILL be more parts added. More pictures will be added. My name is Yusef and I can be reached at 612-275-7398 via call or text. IF YOU CALL OR TEXT AFTER 11PM I WILL NOT RESPOND UNTIL THE NEXT DAY. PM is OK, but I usually don't have time to respond until evenings. Not that I have to say it, but Cash Only please. Part Condition Notes Price -EJ255 Block Assembled 2.5 Turbo Used Gouge in Cylinder 2 - Excellent rods and crank. Good for 2.1 stroker - pair with the 2.0 block below! $200 -EJ255 Block Halves - 100 MM 2.5 Turbo Used Cylinder 4 out of round @ case half bolt relief $100 -EJ205 Block Assembled 2.0 Turbo Used Has a spun rod bearing - Pistons, crank, 3 of 4 rods, and case halves in good condition $200 -WRX Accelerator Pedal bracket 02-05 Used Drive By Wire only $5 -WRX OEM Shift Knob 02-05 Used SOLD -Transmission linkage plate 02-05 + FXT Used $5 -5 spd Short Shift 02-05 Used WRX Only $25 SOLD -WRX Transmission support 02-05 + 06-07? Used $20 -WRX Clutch Slave Cylinder 02-05 Used $30 -Water Pump Rubber shim 02-07 Used $1 -Thermostat Housing 02-07 Used dirty but functional $5 -Water Crossover Pipe 02-07 Used $50 -PCV Case Breather Tube 04 Used $5 -Oil Filler Neck 02-07 + FXT + LGT Used No Cap $10 -WRX Crank Pulley 02-05 Used Needs wire brushing and paint coating $15 -WRX Crank sprocket and bolt 02-07 + FTX + LGT + NA applications I think Used $30 -WRX Oil Cooler Feed Line 02-07 + FXT + LGT Used Corroded but fully functional $5 -WRX oil Baffle 02-05 Used $30 -WRX Water Pump to top of motor piping - Drivers Side 02-05 Used Came from an 04 - some differences between years, but all work $30 -Coolant Filler Tank/Resivour 02-07 Used Steel material $40 -AC Compressor Bracket 02-05 Used $10 -Dipstick and Tube All Used Should fit just about anything $20 -Turbo heat shield - Lower Section 02-07 Used $5 -Head Studs All Used Single Use Head Studs - $3 ea., 30 available $30 -TD04 Turbo Charger #1 Blown Rebuild or use for parts $40 -FXT Clutch and Pressure Plate 04-08 Used 120 Miles, Includes throw out bearing and mounting bolts $50 -Throw out Bearing Many Used works fine, was removed for new bearing preference $10 -Exhaust Manifold Heat Shield - LH 02-05 Used $10 -Exhaust Manifold Heat Shield - RH 02-05 Used Only lower portion $5 -Misc. Motor Mounts Unknown Used $5 -RH Front Timing Cover 02-05 WRX Used $40 -Front Timing Cover 02-05 WRX Used $75 -WRX Oil Pan 02-05 Used $50 -WRX Flywheel 02-05 Used $50 -WRX 2.0 Cylinder Heads 02-05 Salvage Valve covers included, 95% complete, may be missing turbo water feed pipe. Cams took impact in accident; may be salvageable. $100 -WRX Camshafts Set 02-05 Salvage Took impact in an accident - use for cores? Offer -WRX 2.0 RH -Exhaust Cam Gear Chipped 02-05 Damaged $5 -GR-2 Struts Forester Used $10 ea $40 -Forester Springs 04-08 Used $80 -Intake Manifold with TGV's 02-07 Used Impreza or Forester - Note that the TGV's Are side-feed. Includes all TGV Motors $175 SOLD -Side Feed Fuel Rail Kit 04-06 Used $25 -Fuel Pressure Regulator 04-06 Used Stock for side feed $60 -Forester Intake Resonator/Snorkus 04-08 Used Should Fit WRX OK too $25 -Silver Hood Scoop Delete 04-05 Like New $140SOLD -K&N Filter and Kit 02-07 + FXT Used $40SOLD -Stock Filter 02-07 + FXT Like New $5 -04 STI ECU Many Used $100SOLD WRX Inside Timing cover 02-05 Cracked $5 Sti Brake Lines 04-07 Used $20 Airbox to Turbo Inlet Pipe 02-07 + Used $5 Sti B 25 heads 04 + Damaged No avcs lines or banjos, some scoring on all journals - use for parts, cam position sensors intact $100 Sti AVCS Cams 04 + Damaged Scoring on journals, heat spots on lobes - possibly be used for cores or repaired by specialty shop Offer Turbo Heat Shield 02+ Used $10 Lower Passenger Side exhaust manifold heat shied, 2.5 Turbo 06-07 style 06-07 Used $10 Grimmspeed Light Wegiht Crank Pullet 02 + New Never ended up installing $115 EJ255 Block - Complete w #2 Cylinder Score - Crank and 3 of 4 rods are good EJ 255 Block Halves - 100 MM but need to be sleeved EJ205 EJ205 Cross Over Pipe EJ205 Oil Pan STi Cams - Not Stock - scored/for core or repair only TD04 - Blown/For Repair Only All Pictures: http://s1251.beta.photobucket.com/user/yuseforester/library/Parts Sale Phase 1
More parts and Pics added to OP; check out the picture link too. Can send pics for anything you want to see.
Do you happen to have this part? VALVE DUTY SOLENOID Part#: 16102AA300 Its attached to the intake right near the turbo inlet.
Wow, sorry, have been out of commission for a couple of weeks... Oil pan is gone, but flywheel is in good shape and is able to be resurfaced. PM me your number and I will text you pics.
Items left 4/9/13: Part Condition Notes Price -EJ255 Block Assembled 2.5 Turbo Used Gouge in Cylinder 2 - Excellent rods and crank. Good for 2.1 stroker - pair with the 2.0 block below! $200 -EJ255 Block Halves - 100 MM 2.5 Turbo Used Cylinder 4 out of round @ case half bolt relief $100 -EJ205 Block Assembled 2.0 Turbo Used Has a spun rod bearing - Pistons, crank, 3 of 4 rods, and case halves in good condition $200 -WRX Accelerator Pedal bracket 02-05 Used Drive By Wire only $5 -Transmission linkage plate 02-05 + FXT Used $5 -WRX Transmission support 02-05 + 06-07? Used $20 -WRX Clutch Slave Cylinder 02-05 Used $30 -Thermostat Housing 02-07 Used dirty but functional $5 -Water Crossover Pipe 02-07 Used $50 -PCV Case Breather Tube 04 Used $5 -Oil Filler Neck 02-07 + FXT + LGT Used No Cap $10 -WRX Crank Pulley 02-05 Used Needs wire brushing and paint coating $15 -WRX Crank sprocket and bolt 02-07 + FTX + LGT + NA applications I think Used $30 -WRX Oil Cooler Feed Line 02-07 + FXT + LGT Used Corroded but fully functional $5 -WRX oil Baffle 02-05 Used $30 -WRX Water Pump to top of motor piping - Drivers Side 02-05 Used Came from an 04 - some differences between years, but all work $30 -Coolant Filler Tank/Resivour 02-07 Used Steel material $40 -AC Compressor Bracket 02-05 Used $10 -Dipstick and Tube All Used Should fit just about anything $20 -Turbo heat shield - Lower Section 02-07 Used $5 -Head Studs All Used Single Use Head Studs - $3 ea., 30 available $30 -FXT Clutch and Pressure Plate 04-08 Used 120 Miles, Includes throw out bearing and mounting bolts $50 -Throw out Bearing Many Used works fine, was removed for new bearing preference $10 -Exhaust Manifold Heat Shield - LH 02-05 Used $10 -Exhaust Manifold Heat Shield - RH 02-05 Used Only lower portion $5 -Misc. Motor Mounts Unknown Used $5 -RH Front Timing Cover 02-05 WRX Used $40 -Front Timing Cover 02-05 WRX Used $75 -WRX 2.0 Cylinder Heads 02-05 Salvage Valve covers included, 95% complete, may be missing turbo water feed pipe. Cams took impact in accident; may be salvageable. $100 -WRX Camshafts Set 02-05 Salvage Took impact in an accident - use for cores? Offer -Forester Springs 04-08 Used $80 -Side Feed Fuel Rail Kit 04-06 Used $25 -Fuel Pressure Regulator 04-06 Used Stock for side feed $60 -Forester Intake Resonator/Snorkus 04-08 Used Should Fit WRX OK too $25 WRX Inside Timing cover 02-05 Cracked $5 Sti Brake Lines 04-07 Used $20 Airbox to Turbo Inlet Pipe 02-07 + Used $5 Sti B 25 heads 04 + Damaged No avcs lines or banjos, some scoring on all journals - use for parts, cam position sensors intact $100 Sti AVCS Cams 04 + Damaged Scoring on journals, heat spots on lobes - possibly be used for cores or repaired by specialty shop Offer Turbo Heat Shield 02+ Used $10 Lower Passenger Side exhaust manifold heat shied, 2.5 Turbo 06-07 style 06-07 Used $10 Grimmspeed Light Wegiht Crank Pullet 02 + New Never ended up installing $115 EVERYTHING IS BEST OFFER!! Buy this stuff up please!!
