2006 STI | NF Performance "Stage 1" | Rotated PTE 6266 Tuner: Nuke @ NF Performance Chart Coming Soon: Engine/Power Modifications: Manley Turbo Tuff Rods JE 100MM Grimmspeed Coated Pistons Stock Subaru Crank ACL Race Bearings Balanced Rotating Assembly ARP 625+ Head Studs TGV TIC Plastic Deletes FujiK of NF Performance Head Porting Type C GSC Beehive Springs Ferrea Valves Stock Size GSC S2 272 Cam's LA Sleeved Block KillerB Oil Pickup Intake/Exhaust/Fuel: PTE 6266 V-Band Journal Bearing Turbo Fobia Header Fobia Rotated V-Band Uppipe Fobia Rotated 3" V-BandDownpipe Fobia Rotated 4" Intake Fobia FMIC / Piping TurboSmart 40mm EWG TurboSmart RacePort 50mm BOV Invidia 3" G200 Cat Back Exhaust TurboSmart Eboost2 | AEM Oil Pressure | AEM Wideband Walbro 465 Fuel Pump Hardwired ID 2000cc Injectors Fuelab FPR at 45psi COBB AP Speed Density Tune Driveline Modifications: ACT XT Pressure Plate with Monolock ACT Sprung 6 Puck Disc Track: CedarFalls, IA Raceway Timeslip: 10.574 @ 135.10 Continental DW 235 tires Short Gears Photos: Credit goes to Xluben, if you need professional photos of you car he is your man. PM Xluben
Pheng started it and now people are referring to it as it. Need my hood. I maybe platidipping the white red
