Prosport Triple Gauge Install
Discussion in 'Tech, Tips, Newb Info' started by Se7enrex, Feb 26, 2008.
  1. Offline
    Se7enrex Well-Known Member
    Oct 29, 2006
    Message Count:
    1,703
    Here it is, as complete as I can make it..STICKY??
    Also I want to thank Josh @ Import Image for Fast shipping and great product!!!
    These are all MY instructions form MY experimenting...I made these instruction off of personal knowledge
    I am not responsible for damage you or your car may obtain while following my instructions.
    This was performed on an 06 STI...I don't know and can't promise other vehicles will be similar
    This is for wiring a boost, EGT, and oil pressure gauge into the clock pod area on top of the dash
    Post #10 is completed look...here mine are on youtube, just posted
  2. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Step 1...get ready for at least a couple hours worth of work, make sure you have plenty time and a nice open place to work.
    General Tools needed:
    socket set:10mm, 12mm, 14mm
    flat head screwdriver
    fillips head screwdriver
    soldering iron
    solder
    stretch rubber electrical tape(ace hardware)
    heat shrink for small wires
    wire clipper
    lots o' zip-ties
    thread lock/jb Weld
    Specific extras/tools:
    11/32" High speed steel Drill Bit
    1/8-27NPT 11/32" TAP
    Tools that might help
    A welder
    Extra vacuum hose
    zip-lock bags for bolts
    a heater for the garage
    ****Make sure you order the sandwich oil filter adapter from prosport for the fuel pressure/temp gauge*******
    Also you might as well change your oil while your at it...otherwise buy two quarts of oil to be safe
    Step 2
    Lift that dang car up in the air..plenty enough for you to monkey around and get comfortable under there
    remove the plastic skidplate...theres a couple bolts and poppy things on there..EASY
    OK...now we are gonna do the EGT gauge First
    Take off the upper heat shield on the drivers side header---it has 3 bolts, they are all 12mm
    then remove the driver's side portion of the header, i believe these are all 14mm bolts...there are 5 of them..2 on the connection to the crossover and 3 to the block
    pull it out and set it down...smile
  3. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Now you are gonna want to drill a hole 6" down the cyl.3...you want to do it on the outside the manifold..ie on the fender side there is a little circular tab...drill and tap it!(it is the exact size!)
  4. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Step 3
    Now you may choose to use threadlock or you may choose to weld...I did both!*****make sure you remove the sensor from the bung if you weld so you don't hurt it...just weld the bung!
  5. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Step 4
    re-install the header portion with the sensor removed(make sure the bung is on though....test fit the heat shield again and mark it and cut a hole in it where the bung is located so you can run the sensor and wire!
    Now I painted mine black to clean up the look and stenciled on EGT just so if anybody else climbs under there they know whats up...its just convenient!:)
  6. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Step 5
    Now..as far as the oil pressure goes you have two options...buy the sandwich adapter...or buy the plug that goes where the oil galley plug goes(which is located under the inlet to the turbo on the block...its a 1/8" hex bolt!--I chose the sandwich..its easier..a LOT EASIER!...
    so unscrew your oil filter and put the sandwich on(rubber side up touching the engine)-then bolt up a new filter(its basically a spacer....)
    The sandwich has 4 holes to use for what you will, oil pressure, temp etc.... and 4 block off bolts for what you don't use!
    Your oil sender will screw directly into one of the 4 holes!
    This unit WILL screw directly on and will have plenty of clearance to run the lines to...nothing will need to be moved or cut or bent!
  7. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Step 6
    The boost gauge wiring....cut a straight line on the vacuum hose that goes from the oem/aftermarket-diverter/BOV....install the T-fitting supplied with kit....install about 7 inches of vacuum hose off of the 3rd hole...place the little metal air filter supplied on the other end..then take the rest of the tubing and attach that to the other end of the little air filter...
  8. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Important
    NOW__IMPORTANT___
    STEP 7 RUNNING WIRES
    there is a hole about 2 inches to the left of the steering rack underneath the pedals on the floor of the driver's side foot well...rip that little piece of rubber out and it creates about a circular 1.5" hole...perfect for running wires to the engine...
    the hole pops out in the engine right below the brake booster!
    ****I tried running wires through the engine a million different ways...do what you are comfortable with..try to keep all of them away from hot stuff(obviously!)
    Step 8
    Ok.....Rip your dash apart NOW!!!!! Don't break anything!
    start the snaking process...NOTE: it helps to run a wire Down and tape it to the leads and drag it all back up through the dash so that you are not trying to push wires up through....
  9. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Step 9
    Now You probably already have put the gauges in the pod(I have an ATI) so flip them around and look at the back
    each gauge has a power hook-up on either side of it(so two per gauge) This is so you can Daisy chain the gauges together and only have to tap once for power...not 3 times!!!
    Then on the last gauge take the supplied power cord that has 4 colors that are raw wire on one side
    The colors will be black, white, orange, red ( for amber/white gauges)
    or
    black, white, green and red(white/green gauges)
    Take the leads of the wires and connect them to the back of the gauges!
    NOTE: You are probably like" hey, how the hell do i connect the vacuum hose...there is a solenoid included in the kit...plug the vacuum hose on one end and mount the damn thing where you like....then connect the sensor to the back of the gauge with the others!
  10. Offline
    Oct 29, 2006
    Message Count:
    1,703
    Step 10
    Time to wire that power......
    so here is the run down on wires....it is 100% correct
    PROSPORT--SUBARU CLOCK WIRING
    Black--Black
    Red--Blue with Red stripe
    Orange/Green--White with Red stripe
    White--Yellow with Blue stripe
    Then solder and wrap and heat shrink and cover it safely....DONE
    Now put it back together and enjoy!:biggrin:
    ***** Video of them in my car on youtube*********....
  11. Offline
    fobiawrx Fabiola
    Aug 28, 2005
    Message Count:
    3,800
    can we post yet?
  12. Offline
    Apr 6, 2006
    Message Count:
    4,735
    Do they recommend thread locker or JB weld on an NPT thread??? 1600 degrees????
  13. Offline
    Oct 29, 2006
    Message Count:
    1,703
    i have no idea..It probably all burned off when i welded over it
  14. Offline
    Justin Well-Known Member
    Nov 7, 2004
    Message Count:
    6,301
    thread locker will burn up right away. JB weld...well that SHOULD too but i used some on the brass fitting and it never burned up which is weird.
  15. Offline
    Oct 29, 2006
    Message Count:
    1,703
    I noticed when I re-wired it after driving it for a day the threads were for sure still locked but all the red had been burned black and charred---still it did its job:)
  16. Offline
    fobiawrx Fabiola
    Aug 28, 2005
    Message Count:
    3,800
    you have a egt and a exhaust gas temp gauge?
  17. Offline
    Oct 20, 2006
    Message Count:
    6,850
    Nice job Will, and I don't mean to be an ass but aren't you selling this car?
  18. Offline
    Dec 18, 2004
    Message Count:
    16,244
    i was just gonna say that
  19. Offline
    Oct 29, 2006
    Message Count:
    1,703
    fixed
  20. Offline
    Oct 29, 2006
    Message Count:
    1,703
    I wasn't going to say anything yet, cause I'm not 100% sure, but I am pretty sure I will be keeping the car:):biggrin:
  21. Offline
    SubieDave Well-Known Member
    Aug 3, 2007
    Message Count:
    1,891
    Turn them on and take a pic! I want to see
  22. Offline
    Oct 20, 2006
    Message Count:
    6,850
    Stop dropping money into it everyday so you can keep it then. Oh and did you get that orange wheel and jazz.
  23. Offline
    Oct 29, 2006
    Message Count:
    1,703
    no to th eorange stuff, working on a video
  24. Offline
    hella_sti Well-Known Member
    Feb 16, 2007
    Message Count:
    1,121
    you don't need any type of threadlock on the egt bung, its an NPT thread pitch which means that it'll have a self tightening effect as you make it tighter, just a suggestion.
  25. Offline
    Oct 29, 2006
    Message Count:
    1,703
    video just posted...to the top or post # 10
  26. Offline
    Oct 29, 2006
    Message Count:
    1,703
    True, however we all know that that doesn't always work...It was the correct stuff but it just wasn't tight enough....so i welded
  27. Offline
    Apr 6, 2006
    Message Count:
    4,735
    Whenever I tap something with an NPT thread, I check it as I go because I want it to get as tight as I want it to. Its always easier to tap it a little more. Going back isn't.
  28. Offline
    Oct 29, 2006
    Message Count:
    1,703
    exactly, I know, that is a very good basic idea...i kinda was planning on welding anyways so I jumped the gun a bit!
  29. Offline
    Iroc-Z Well-Known Member
    Jul 18, 2006
    Message Count:
    2,283
    Good luck with the electric boost gauge. I am on my third sending unit. I am going to order a mechanical one next week.
  30. Offline
    Oct 29, 2006
    Message Count:
    1,703
    1. did you have prosport? 2. Where is thesolenoid or sending unit located(where did you mount it?
    where mine is located i could replace it twice a day inside my car without it bothering be..but I would like to not have to
  31. Offline
    Jul 18, 2006
    Message Count:
    2,283
    Mine is under the hood. I have it mounted by my fuse box. I am unsure why they die and prosport doesn't know why either.
  32. Offline
    mlgez Well-Known Member
    Mar 13, 2006
    Message Count:
    2,741
    Any more reviews or suggestions on this install? After everything looks good we can move the install part of this to the " Tech, Tips, Newb Info" area.
  33. Offline
    Oct 29, 2006
    Message Count:
    1,703
    ok its all done
  34. Offline
    blake Well-Known Member
    Jan 19, 2008
    Message Count:
    Anyone know where I can get the Sandwich he's talking about?
  35. Offline
    Nov 8, 2006
    Message Count:
    6,246
  36. Offline
    Ryan Sled drifting master
    Apr 27, 2007
    Message Count:
    2,171
    Moving to the write-up section.
Share This Page
