02 2.5RS/WRX Struts wih Eibach Pro Kit+more
Discussion in 'For Sale : Car Parts' started by esperunit, May 25, 2005.
  1. esperunit
    esperunit Well-Known Member
    I'm getting my STi Ver 7 spec C suspension in so I need to get rid of this stuff.
    JDMpartsTX, a well known importer is selling the same setup for $250 plus shipping and those have 40k on the struts and springs.
    mine are almost 40k on the struts, less than 6k on the springs. The struts are fine, theyre on my car right now if anyone needs to see how they perform, i'll be at firestone on friday. Ride height is fairly low, looks good and the struts are fine, no leaks or problems of any kind. The eibachs are designed to work with the stock struts and not to overwear them like a lot of other aftermarket springs.
    long story short, $220 and they're all yours.
    Also, some other RS stuff on super sale:
    13mm stock swaybar W/ swaybar mounts - $20
    good for returning the car to stock. the mounts are actually valuable since many swawbars over 19mm will bend, snap or damage teh stock mounts at some point, so theyre good to have for a replacement if you don't have upgraded mounts.
    Stock 2.5RS/WRX springs - $15
    again, good for returning car to stock. They're 15 bucks because they're actually worth $10 as scrap metal. I checked.
    Stock 2.5RS/WRX rear endlinks - $5
    You can take these and put in some whiteline bushings, and save on buying a full metal endlink. People actually do this, I swear.
    A k+n style cone filter - $0
    Has tears from overclamped hose clamps on boot. a rubber sleeve will fit just fine and fix it. I think this one was made by Tenzo R.
  2. TheWRX
    TheWRX Well-Known Member
    Zak I'll let u know about the 15$ srings...I might be able to use them...
    Mohd
