Parts leftover from my 2.5 swap. I've sold alot of stuff so far but still have some things left. 1. '02 WRX Rear LSD (manual) Diff 143k miles with new axle seals (not installed) $100.00 2. Male rear axles 19k miles $125 3. Male Front axles 19k miles $125 4. '04 Baja TMIC $80.00 5. Stock Up pipe (I have 2) $45.00 6. Drive by wire Throttle Body only (Intake manifold sold) $45 (from '04 Baja Turbo) 7. Drive by wire pedal assembly. Good for swaps. $offer 8. Turbo Transmission Crossmember. Good for turbo swaps. Has space for downpipe. $offer 9. Stock WRX Injectors (Russ you still want these?) 10. Sold 11. VHT High Temp Wrinkle Paint. I went EVERYWHERE in the cities for this and no one had it. Mail ordered 2 cans and only used 1 on my stock WRX manifold. 1 can $9 12. '04 Baja Turbo Driveshaft $100 (not the same length as a WRX one, maybe the same as a forester?) Ends are the same however. 19k miles Email me or PM me: [email protected] Thanks, Chad
I do have a pump. It's from a Baja Turbo with 19k miles. It will work but you need to use the Baja lines (which connect to the impreza rack) I have the lines and they would be included with the pump. $45 for both?
I think i'll take the (Brand New 2002 WRX OEM Spark Plugs in Box (Sell for $10-12 each online) and 2 OEM Oil Filters $35 for all)....I'll let u know... U got a PM.. Mohd
Let me know if theWRX is gonna buy the spark plugs and oil filter. If not, I'm will buy the spark plugs and oil filter asap.
