My car sounds like a Damn Honda chasing it's revs up down up down also I'm throwing p0508 idle air control circuit low code. one of the previous owners swapped a 06 5mt into the car under normal driving it's fine but under 10psi the clutch slips(most of the time) so if anyone has a clutch that would be fantastic
5073413003 texting would be preferred text me anytime Mar not answer if it's to late but I will respond in the am
I had to do a iac on my 02 wrx and I work at a auto parts store so the part was quite a bit cheaper. Through Napa for a walk in customer I think it was like 390 plus tax but I got mine for 217 plus tax. And if you cant get the screws out get a regular socket hex head bolt to put in there cause I had to drill out one of the screws and extract it then put 2 new ones in cause the original ones stripped out when I was trying to get them out they were on so tight.
