Engine wire harness $150 Engine bay harness $200 Engine ECU $150 Booster controller $20 Timing belt cover all 3 pieces with hardware $75 Oe headlights w/ painted Psm carbon fiber eyelids will need buffed and cleared $100 Brake lights no cracks $80 pair Front Brake calipers w/lines $80 pair Brake rotors $20 pair Brake rotor dust covers with screws $40 pair Complete abs sensors with wires and screws $40 pair Misc gaskets 2 Grimmspeed gaskets 2 factory $25 Coil packs all 4 $100 Motor and transmission mounts w/ pitch stop $40 LCA'S $50 pair POWER steering pump $60 POWER steering line's with reservoir $60 A/C compressor $60 Starter $50 Coolant overflow tank $30 each Axle front good boots $40 Intercooler w/y pipe $100 Intercooler to throttle body hose $5 pair Bpv w/ hose part $40 Bpv w/o hose part $20 Alternator $50 Alternator cover $20 Dash cluster bezel $30 Misc Center dash with vent cover w/side vent $25 Turbo inlet tube $40 Airbox hose $10 Psm hood scoop $40 Psm grill side pieces with clips $30 Manifold as seen with tgvs, Grimmspeed gaskets,8 mm spacers and new bolts. Missing passenger side fuel rail $150 Factory 6 disc cd player with cassette $50 Complete set of heads still on the engine was told they are good from the shop. $400 Engine short block ring failure to #4 All prices are obo
Make offers I want a new turbo and tune. The turbo inlet tube and the power steering reservoir and lines sold. Motor and transmission mounts are pending.
