02 wrx upper raidiator hose.
Discussion in 'Want To Buy : Cars/Parts' started by JasonoJordan, Feb 12, 2013.
  1. JasonoJordan
    I have silicone Gimmick hoses and used worm gear clams on the upper hose(i know i know bad idea) It seems as the upper one may be worn through around the clamp on the crosspipe as I keep getting a slow drip from there when the car is warm. So im going to inspect the damage in the light 2 maro morning. Just wondering if anyone has a stock one to get me by till I can pick up another set and get the correct clamps for it. Thanks. Jason
    Im over in maplewood as well so closer the better as I dont want to drive a ton with this leak.
  2. Terry Ammerman
    If you can't find one closer, I have a couple. You can have it, but I am in Elk River.
  3. JasonoJordan
    Thanks. I'll let you know terry.
  4. JasonoJordan
    On further inspection its not worn it looks like there is some buildup/corrosion on the sealing surface for the coolant cross tube outlet.
  5. JasonoJordan
    Cleaned up sealing surface. Still having a problem getting the silicone hose to seal. Any sugjestions?
  6. Terry Ammerman
  7. JasonoJordan
    They are on the way here. Won't be here til wens. :-/ weird part is I've had these on here for about 4 years with only.occassionly having a slow leak now its gotten bad.
  8. pillboy
    Whenever I've had sealing issues on coolant hoses, I've used Permatex No. 2. It took care of the leak and never had any future disassembly issues.
  9. JasonoJordan
    Thanks for the advice! I'll give that a try
  10. JasonoJordan
    Started to flex the hose when the car was warm.found a pin hole in it. New from dealer 20 bucks picking it up today since I'm in Bloomington
  11. JasonoJordan
    Lesson learned on worm gear clamps.
  12. JasonoJordan
    Damages
