04 sti fs
Discussion in 'FS: Cars, Motorcycles, Boats' started by freeze2104, Feb 16, 2013.
  1. freeze2104
    freeze2104 Well-Known Member
    The car runs great, the body has 130xxx and the motor was replaced about 7k miles ago. I had the guys at RS Motors take a look at it after I bought it and they said everything checks out and looks good. The block was replaced due to a oil pick up failiure. It was replaced with a new block and all oem parts from Subaru. The heads were also redone along with the timing belt, water pump, ect. The car does not leak or burn any oil. There are a few dings on it as we all know how tough subi paint is. It has 3 gauges in the car, boost, oil preasure, and air/fuel. Boost doesnt work properly and the other 2 arent hooked up.. but they look cool.. The original owner never got around to it and I was going to replace with some defi gauges but havent had the time or money. The car has an hks ssqv blow off valve on it, I have the stock bpv and tube but havent had time to put it on. It has an spt intake on it as well. The front 02 was replaced about 100 miles ago and now everything runs smoothly. Clutch was also replaced when the motor was pulled. It has an in dash touchscreen and the trunk, wing, and hood scoop are painted black. Something I also havent had time to get redone. Looking to get $15500 for it. Title is clear and I have it in hand. If you have any questions, please text me. Its the best way to get a hold of me. 952-two seven zero-0010 The reason for selling is I no longer have a job and with 3 cars this one has to go. I wish I didnt have to sell.
  2. freeze2104
    forgot to add.. the car currently has winter tires on it with about 90% tread left.
  3. freeze2104
    Another part I forgot... Along with the new motor, a new turbo was also installed.
  4. souy07
    souy07 Well-Known Member
    seems like a pretty good deal.. GLWS!!!!
  5. freeze2104
    Car sold. Please delete/lock thanks.
  6. thakrazymule
    thakrazymule Active Member
    Royalton
    That was a short ownership.
  7. BroCo
    BroCo Moderator Staff Member
    St.Francis Minnesota
    Congrats on the sale.
