ok, i have been looking at coilovers. i was wondering if any of you know what ones will work with the 05's. i have heard that the 04 and 05 suspension isnt compatable, or is that just stock suspension parts. i also thought about just doing springs (i also heard that the 05's dont need aftermarket shocks/struts with aftermarket springs). anyone know the stock STi spring rate? TIA
This has the 2004 STI USDM model spring rates, but not the 2005. not sure if these are right, just came across it a few weeks ago. http://www.ravensblade-impreza.com/techdocs/spring/spring.html Paul
Will, check this out if you're looking for STi coilover for your 05. http://forums.nasioc.com/forums/showthread.php?t=625733&highlight=2005+suspension Will, go here for your spring rate question. http://forums.nasioc.com/forums/showthread.php?t=615097&highlight=2005+suspension Hope it helps.
