'07 STi daily driver clutch replacement: OEM or aftermarket suggestions
Discussion in 'Modifications And Maintenance' started by SAWD, Oct 19, 2015.
  1. SAWD
    SAWD Active Member
    Car: 2007 Subaru Impreza STi Limited SWP 6MT
    Pertinent Modifications: None.
    Hey folks, long time owner but haven't posted for a long time...
    My '07 STi Limited has a clutch that has started slipping. Was going to have RS Motors replace but looking for suggested replacement options. Daily driver, all street use.
    Heard a lot of good things about "South Bend Stage 2 Endurance Clutch" or the "daily" variant, thoughts on that or other options? Resurface OEM flywheel or replace?
    Noob here, please be gentle.
  2. AspitFire
    Exedy Stage 1 full face. If your flywheel is still good have it resurfaced.
  3. belalegosi
    belalegosi Well-Known Member
    If you are on stock power, why not stick with a stock clutch?
    tehfuzz likes this.
  4. idget
    Save a few hundred bucks and go with an oem exedy kit like Josh said. Should be like $3-400 for everything minus labor (compared to 6-700 for the southbend clutch kit).
    SAWD likes this.
  5. whitey
    whitey Well-Known Member
    I have 45,000 miles on a Competition Clutch stage 2 with a Fidanza flywheel and still going strong.
  6. Medic_538
    Medic_538 Well-Known Member
  7. Roon
    Roon Well-Known Member
    Not sure on fitment - but I have a clutch I took off my 15' STi at 16.5k miles - it's your's if you want it and are looking to save some cash.
  8. SAWD
    SAWD Active Member
    Thanks folks!
  9. iand464
    iand464 Well-Known Member
    I put in a low mileage used sti clutch in my old wrx and had no issues with it for over 100k with with over sti power levels. The 15 clutch is probably the same. It's a exedy
