07 WRX caliper conversion onto a 07 2.5i
Discussion in 'Modifications And Maintenance' started by mke723, Mar 24, 2009.
  1. mke723
    mke723 Well-Known Member
    I got front and rear Calipers from a 07wrx, 4pot fronts, 2 pot rears, just wondering if im going to have any fitment/ mounting isues? i know i might need a 5mm wheel spacer, but im more concerned with the actual mounting. let me know if i will have any issues, thanks
  2. Shibbs
    Just make sure your wheels are large enough diameter to clear them! You'll love them.
  3. bobafett04wrx
    bobafett04wrx New Member
    Lucky!
  4. putz
    putz Well-Known Member
    TEMPTED TO LIE AND SAY "nope, will not work.... you should prolly sell them to me and I'll find a good home for them..."
    you are lucky!:biggrin:
  5. carl
    direct bolt on. or donate to me so I have a spare set
  6. subytek
    subytek Well-Known Member
    You have a lot of work ahead if your putting the rears on.
  7. driftin240
    driftin240 Well-Known Member
    Rears require the replacement of the backing plates and such. Rotors are vented, and are much thicker than the rotors on your 2.5i. When replacing the backing plates, you have to remove the hubs, which means replacing your wheel bearings.
    The fronts are easy, the rears are not.
  8. carl
    i stand corrected, i thought the backing plate was the same on the 2.5i
  9. mke723
    thank you for your input. lucky has nothing to do with it, spent months looking for sets online, nothing popped up till last week, but got a deal on ebay, very few bids.. sounds like im bragging, ohh wait, i am..
  10. mke723
  11. mke723
    carl i will donate them to you, but only if i get to drive your car in every rally the car is equiped with my brakes? :laugh::laugh::laugh::laugh::laugh::laugh:
  12. mke723
    Where do i find this backing plate?
  13. piddster
    At the dealer...
  14. subytek
    And wheel bearings with seals. Also you will need rotors, if they did not come with them.
  15. mke723
    IS there anthing needed for the parking brake?
  16. mke723
    I DID FIND KARTBOY BACKING PLATES THAT, ACCORDING TO TOM AT KARTBOY, BOLT DIRECTLY INTO STOCK BACKING PLATE AND NULL THE HUB REMOVAL AND NEW BACKING PLATS, AND COST $25 LESS THAN THE TOTAL FOR NEW PLATES AND BEARINGS.
    KB-020Brake - FHI 2pot Rear Adapter ($ 225.00)
    FOUND THEM ON SCOOBYMODS.COM
  17. stiv5
    stiv5 Well-Known Member
    All you need is the Kartboy 2pot adapters and 06-07 Wrx rear rotors to make them fit. Make sure your front rotors are the same sizes as all 02-07 Wrx rotors. Also how much did you pay for set of 4pot and 2pot calipers? If you don't mind tell us.
  18. rsverv
    rsverv Well-Known Member
    i went this route with my 2pot rear setup
  19. mke723
    i got them for 850 on ebay, almost got swiped with a min 30, dude tried to outbid me, they are off a totaled 07 in florida.
  20. stiv5
    Cool, good price indeed. Did you check to see if your 2.5i rotors are the same sizes as the 06-07 Wrx rotors? I also bought a set of the 06 Wrx 4pots and 2pots with 06 Wrx rotors for $600 last month. I just can't wait to put them on. I am going to get the Kartboy 2pots adapters to make them fit. Post up some pictures.
  21. mke723
    it appears i have been miss-led, the 2.5i front rotors are not the same as the fronts on a wrx, loookes like i need to get new ones, any good sugestions? im not a fan of th drilled cuz they crack, any one running slotted or dimpled? or should i just buy brembo blanks and call it good? remember i will be rallyXing it, and i like to practice rallyx in the feild at home.
  22. Shibbs
    Just get cheap ones. Replace them whenever you replace your brake pads.
  23. boomer
    boomer Well-Known Member
    Your stock brakes would have been plenty for rallycross. Short tracks, very little braking and a loose surface don't require anything fancy for brakes. I would get stock WRX rotors and call it good.
    Or you could sell the 4 pots and put it into tires and suspension;)
  24. mke723
    have u ever drivin a 2.5i? the stock brakes can barely handel stoping at a stop sign, much less any agressive driving but thats stock at 44k, yes i checked my pads 5k ago, still plenty left, back brake rotors look like they came off a MTN bike tho.
  25. ArcticWolf
    ArcticWolf Well-Known Member
    I have a 2.5i, and the stock brakes are fine for rallycrossing. The stock pads may not be the best, but the rest of the setup is fine.
    You do realize that stopping ability is limited more by tires than by the brakes, right? The stock brakes will lock up the wheels (abs kicks on) just fine... bigger brakes are just for fade resistance, or bling.
  26. carl
    you shouldn't have to brake during a rallyx
    (unless you drive an audi. But then it's spelled break)
  27. ArcticWolf
    On another note.... seriously, just show up to an event. I was in the same boat... planning this that and whatever, and then I went to the RallyX in corcoran.
    The car isn't going to be what's holding you back, for the first few events at least. If you can find someone willing to do it (shouldn't be too hard), let someone else drive your car at the event. It really puts a highlight on how much there is left in the car that you're not wringing out.
  28. boomer
    The 4/2 pots are a great upgrade for the streat and a good bit of track use.
    I didn't mean to rain on your parade. You got a good deal on a nice set of brakes. I was just thinking only rallycross not daily driving, autocross, or track days.
    The thing with gravel, ice, mud, whatever, is you only have as much stopping power as the surface allows. Big brakes, small brakes, or draging the feet Flintstone style, if traction is limited it all comes down to how much grip the tires (or your feet:biggrin:) have.
  29. mke723
    Yes, fully aware, i do plan on auto crossing, and track days too, didnt put that up above, but thanks for your comments, and i guess i will see you at the tracks.
