1981 Kawasaki 305csr
Discussion in 'FS: Cars, Motorcycles, Boats' started by babiker712, Sep 6, 2012.
  1. babiker712
    babiker712 Well-Known Member
  2. babiker712
    Updated ad to include pics
  3. babiker712
    BUMP
  4. babiker712
    Discovered a minor leak from the carbs (needs a new O-ring) and the main jets are clogged. I don't have the time to pull them and clean them, so I'm selling as-is for $650. I have the manual which details disassembly if you want to clean them and save a bunch of money on a great bike. Local shop quoted $240 to do it. It is running and will run at low speed just fine as the carbs are getting enough gas from the idle jets, if you want to test ride.
  5. babiker712
    I pulled and cleaned the carburetors. Spent about $80 in parts to replace various Orings, get new fuel Tjoint, line, filter and clean gas tank. Now runs, no leaks but has an idling problem I'm sorting out. It's idling at about 5000 rpm when started. I don't have tons of time to keep tinkering on it (likely just needs some tinkering with fuel/air ratio). Selling as-is for $800 if anyone is interested.
  6. babiker712
    sold. lock it up
