Hey Everyone! We recently parted out this 1999 Forester that was in a roll over accident. All parts that are good to sell will be available. We test and inspect parts to our best ability and take photos of them as well. If you don't see a part listed, feel free to ask and I will see what we have available. Not all parts are listed due to the amount. Photos are available upon request and shipping quotes can be determined if you give me your zip code. 1999 Forester Miles: 78,156 Color: Silver Damage: Rolled Over **Exterior Parts** Silver/Black Grille W/Emblem - $75 LH Headlight w/Broken Mount - $75 RH Headlight “Good” - $115 LH Fog Light w/Grille Protector - $40 RH Fog Light w/o Grille Protector (one tab repaired & one broken) - $15 Silver Hood - $50 LH Front Silver Door Complete - $150 RH Front Window Regulator/Motor - $30 LH Black Power Mirror - $30 LH Rear Silver Door Complete - $150 RH Rear Window Regulator/Motor - $30 Pair Of Luggage Crossbar Clamps - $15 Black Luggage Crossbars - $30 LH Tail Lamp Good Shape - $60 RH Tail Lamp Good Shape - $60 Back Door/Hatch Silver Complete - $175 RH Front Door Window Glass - $30 LH Front Door Window Glass - $30 **Interior Parts** Dash Mounted Cup Holder - $15 LH Knee Trim w/Fuse Box Cover - $25 Radio/Temp Control Bezel w/Ash Tray - $25 RH Front Cloth Manual Gray Seat - $50 LH Front Cloth Manual Gray Seat - $50 Black E-Brake Handle - $25 Speedo Cluster Harness - $50 Seat Belts - $30 A Piece: LH Front Retractor Assembly Gray RH Front Retractor Assembly Gray RH Rear Gray Male/Female Assembly LH Rear Gray Male/Female Assembly Gray Rear Center Male/Female Assembly Gray Map Light w/Clock & Glasses Holder - $25 Rear Seat Back Only - $75 Rear Seat Bottom Only - $50 Set of 4 Gray Carpet Mats - $15 Center Console w/Cup holder Lid, Gray - $50 Rear Cup Holder - $25 Gray E-Brake Bezel - $15 Black Shift Bezel - $15 A/T Floor Shift Assembly - $40 RH Gray Vinyl Visor w/o Mirror - $15 AM-FM-CASS Stereo - $50 Owners Manual w/Green Case - $25 **Engine Parts/Under Hood** Short Block With Piston/Rod Knock - $500 RH Head w/Cover, 78K Miles - $125 LH Head w/Cover, 78K Miles - $125 Fuel Pump Assembly - $50 Intake Manifold Complete - $75 Fuel Vapor Canister - $15 LH Camshaft Pulley - $50 RH Camshaft Pulley - $50 Complete Timing Cover Set - $75 Engine Cradle/Crossmember - $75 ECU 22611AE850 - $75 Alternator - $40 Starter - $30 Blower Motor - $25 Windshield Wash Reservoir Assm - $25 Fuel Tank Wire Harness - $50 Radiator - $50 AC Condenser - $50 AC Compressor w/Belt Tensioner - $50 **Drivetrain/Steering/Suspension** Steering Intermediate Shaft - $20 Steering Column w/Key - $75 Good Clock Spring - $50 Pair of Transmission Hoses - $30 Auto Transmission Tested, Clean Fluid - $600 Trans Crossmember - $50 Drive Shaft w/Good Joints - $50 Rear Differential 4.44GR - $125 Axle Shafts Front And Rear - $40 A Piece RH Front Lower Control Arm - $40 LH Front Lower Control Arm - $40 Front Sway Bar w/Links - $40 RH Front Strut Assm - $40 LH Front Strut Assm - $40 LH Front Caliper w/Hose - $25 RH Front Caliper w/Hose - $25 Steering Gear Rack - $50 Power Steering Pump Assm - $50 Warranty Information: Everything that is good on our cars are for sale. Please don't hesitate to ask.* Please keep in mind we may not always have the lowest prices but we try our best to price our parts as fair as possible according to condition and miles on the car. If you think something is priced too high, don't hesitate to bring it to my attention. Everyone makes mistakes sometimes. All of our parts carry a 90 day parts warranty and we really do care about not selling junk parts. If for whatever reason you have a problem with the part I will do everything I can to make sure you are happy with your purchase. We have the car dismantled and have pictures of most of the parts. If you would like to see a picture of the part you are interested please just ask and I will post it up for you with a price. Please ask any questions you may have, I will try to keep up with the PM's and thread posts... Thanks!! Isaac
I'm looking for the temp sensor for the compass/temp/altimeter pack. Should be behind the front grille. Thanks!
Hmm I don't see it listed in inventory but I will see if I can find it unless it was damaged in the accident. I will get back to you on this.
I'm not seeing that we have the sensor any longer but I will continue to keep my eye open for one and let you know if I find something. If you need anything else, let me know.
Any chance you'd entertain the thought of cutting out a 2" radius of the entire rear pass wheel well lip? I just picked up a '99 this weekend and that is really the only rough spot on the body.
Ya I don't see why not. Is there any specific spot you would prefer it be cut out of? If you email me photos of the spot on yours you would be replacing, we can take it from there. Email is [email protected]
