what is the diffrence from the na block to the turbo block? if i was going to sleve the block and get new internals, does it mater what block i get?
The 22NA is open deck, the 2.2T is closed deck...the closed deck is what makes the 22T the stronger of the two blocks.
turbo 2.2s have oil squirters, WOOOOOOOOOOT raise your hand if you have an ej22T *raises hand* jeaaaaaaaalous?
EJ22T here too! w00t!!1 Piston Squirters, Closed Deck, Forged crank and rods, Powerful oilpump...you can't lose with t3h EJ22T!!!
You can't "MAKE" and ej22t, you can only acquire it. The EJ22T is the only 2.2L Closed Deck Block with Piston Squirters...those things can't be "MADE."
You mean you cant widdle this out of chunks of raw materials with only a hammer and a chisel? Damn, time for me to find another option for a motor then.
