2.5 Headgasket problem.
Discussion in 'Modifications And Maintenance' started by Iroc-Z, Jan 28, 2008.
  1. Iroc-Z
    Iroc-Z Well-Known Member
    New Germany, MN
    Just throwing this out there.
    We have a 01 Outback with a SOHC 2.5 that came in for leaking head gaskets. Pulled the heads and sent them to the machine shop. Had them pressure checked and shaved. Reinstalled with new turbo oem gaskets from the dealer. Vehicle still gets hydrocarbons in the coolant. We pulled the heads and inspected. No problems found. We then reinstalled them and still over heats and gets hydrocarbons in the coolant. I am kind of at a loss. Has anyone seen the blocks crack on these engines?
  2. AWDimprezaL
    Monticello.
    we did just do a cracked block, but the car was sooo severely overheated it was terrible, on an 04 2.5RS
  3. Iroc-Z
    New Germany, MN
    Was the crack vary visible?
  4. AWDimprezaL
    Monticello.
    was not visible at all
  5. Yang
    Yang Well-Known Member
    mpls
    just curious, y use turbo gaskets?
  6. AWDimprezaL
    Monticello.
    because its a beefier gasket, we have hundreds of them on the road right now without issue
  7. Iroc-Z
    New Germany, MN
    Second that. I just buy the gaskets from the dealer and have zero problems.........Except for this one.
  8. flstffxe
    flstffxe Well-Known Member
    Coon Rapids
    the heads may be flat but is the deck of the block flat?
  9. Iroc-Z
    New Germany, MN
    Unsure. But the heads were not even that warped. After talking to Erik I think the block is cracked. So either way it needs a motor.
