How knows this or might have info on this. I'm thinking as a project that i wanna go with STI internals for more Boostz. But I know my stock internals are already mad at boost right now, but they are holding still. So i'm thinking about upgrading Pistons and Rods plus new rings and bearings... But i need to know if the Bore size is the same. To see if they will fit or not.
I am pretty sure that the bore is the same between the RS and the STi 2.5ls. I will do some searchign and see what i can find. EDIT: did a quick search. initial results are showing that both at 99.5 bore and 79 stroke
What? I'm thinking that i'm gonna for sure do STI pistons and Turbo rings. But we'll see. Maybe i'll save that for next year.
yes the turbo internals will fit. how ever the rod lengths are different. the wrist pin in the turbo rods are 1.1mm lower in the piston then the na are. thus the rods in the turbo engines are 1.1mm shorter too.
