2 parter:: Do I have a problem? / Lighting Recommendations
Discussion in 'Modifications And Maintenance' started by COBBsoobyStage1, Jan 22, 2008.
  1. COBBsoobyStage1
    COBBsoobyStage1 New Member
    DT Minni
    Last spring I replaced one of my fog lamps. Now both are out and 1 headlight is out. Do I have an electrical problem?
    Secondly, should I just replace them with oem or is there something better for not much more dinero? :ugh:
  2. AspitFire
    MN
  3. COBBsoobyStage1
    DT Minni
    I don't know what bulbs I need for my fogs or low beams...
  4. AspitFire
    MN
    9005 (hb3) headlights candlepower sells a narva 65w +30bulb for your headlights
    h3 fogs candlepower sells the osram nightbreaker +90 bulbs for your fogs
  5. nm+
    nm+ Professional Hypocrite
    3 hours from every climate on earth
    Sounds like bad luck
    FWIW, for fogs, I like Hoen Endurance.
    For lows, look for ostram (not sylvania) silverstars. They're not easy to find, try daniel stern.
  6. AspitFire
    MN
    stern gets his bulbs from the above site
  7. nm+
    Well then, go there ;)
  8. driftin240
    driftin240 Well-Known Member
    Out West
    Make sure the o-rings on the back cap of your fog light housings are intact. If they let moisture in, you may have problems.
  9. COBBsoobyStage1
    DT Minni
    Not too much moisture in the air in these parts.
