does anyone has this laying around...the metal clips onto the brake calipers??? my brakes are knocking since i threw my old one's away! and dealership is like 30 bucks for it! anyone have any use or new laying around???
When did you get these? I don't think anyone has this part that you're looking for as they belong together with the brakes as a kit. Good luck!
Haha! I have the part you are looking for! (hopefully) Ok, so are you talking about the butterfly clips that sit inside the brake caliper or do you need the shims that slip onto the back side of the brake pad? I'm guessing that you need the shims because without the butterfly clips, the pad won't fit into the caliper. The shims are optional and yes, they do reduce noise. What I have is part # 26233AA120, qty 4. Since there are two pads in each caliper, you'll need 4 to accomodate both left and right sides. These are for front 2-pot calipers on an '02 WRX (stock). I imagine they will fit on some other models, but I cannot promise that. They are OEM Subaru Geniune Parts, Made in Japan. These are the exact same ones you would get from a dealer. Now here's the best Subaru parts website ever! http://www.subaruparts.com/diag/?model=5A&year=2002&style=WRX&body=sedan&scn=2&category=262-1 On this page, the shims I have are part # 26233D. For reference, the butterfly clips are part # 26232. Notice when you click on the part you want, it will give you the correct Subaru part #. Call or PM me if you want them. ~Dan 612.220.3648 EDIT: I should add that these are brand new, unopened, never used.
