2000 2.2 timing tool
Discussion in 'General Subaru Discussion' started by Buddy's sube, Feb 6, 2019.
  1. Buddy's sube
    Buddy's sube Active Member
    Can someone give me a link if there is tool to hold the the driver side cams in place while installing a the new belt(timing)? I did this job on an 02 wrx 2.0 and they kept wanting to wonder. I’m assuming it’s a similar job. Thanks in advance
    Joshua
  2. Krazylegz1485
    Is it a DOHC motor like the WRX 2.0? If so, I can show you the tool I use.
    joebush44 likes this.
  3. idget
    Company23 camlock tools:
    http://www.company23.com/products/camlocktools/517
    http://www.company23.com/506
    There are generic versions of both on amazon as well.
    Alternatively, the factory tool (and the knockoffs) go around the cam gears rather than inserting into the bolts.
    Pull the tensioner pin before releasing the camlock tool to keep the belt from skipping a tooth after getting it lined up (adding spring clamps at the pulleys helps too).
  4. Buddy's sube
    You know I’m not sure haha I just assumed it’s dual cams. I just picked it up yesterday.
  5. Buddy's sube
    Thank u sir!
  6. joebush44
    joebush44 Well-Known Member
    It's SOHC and it's way easier to do than on the DOHC WRX you worked on previously. You don't need any special cam hold tools
  7. joebush44
    ...that's assuming you're not working on a 22B that was equipped with an EJ22G DOHC motor. I'm guessing not :D
  8. Buddy's sube
    Perfect! The wrx wasn’t that hard just made me super nervous when they kept trying to move on me. I haven’t dealt with many Subaru’s. I’m usually a glutton for punishment and run Audi’s.
    Krazylegz1485 likes this.
  9. Todd
    Todd The Originator Staff Member
    No 2.2 in this country was DOHC.
    Chux likes this.
  10. Buddy's sube
    One more question is there Subaru vendor everyone uses?
  11. idget
    Personally I always check with Josh Nahm at importimageracing first. He's been sponsoring this forum for about 12 years and always has some sort of discount/combo deal/ price match (he'll actually beat any price you send him) available.
    Locally, I check with Jesse at JM auto.
    After that, amazon.
  12. Buddy's sube
    Ok thanks. I’m in Rochester.
