2004 Subaru STi [Bismarck, ND] - built motor, caged, etc
Discussion in 'FS: Cars, Motorcycles, Boats' started by BadlandsRacer, May 11, 2017.
  1. BadlandsRacer
    BadlandsRacer Well-Known Member
    I am asking $18,000 $14,000, but I am open to offers on this car. Questions should be directed to me via PM.
    The car runs/drives, is garaged, and has been meticulously maintained (oil changes before & after every event using AMSOIL Dominator 10w30, regular spark plug replacements and 30/60/90 services, etc). It has the normal wear and tear you'd expect from a track car (chips in the front bumper paint, etc). It desperately needs tires, and needs a tune, as it is running on a base map from the changes made last year.
    Engine
    2.5L built by EFI Logics in 2010:
    New Subaru OEM case halves
    STi nitrided crankshaft
    ACL Race bearings
    STi rods
    EFI Logics-spec 99.5mm pistons
    Manley 1mm oversize valves, springs and titanium retainers
    Kelford R199-B performance camshafts (duration: 264/264, lift: 10.7mm)
    ARP head studs
    Shimmed 08+ STI oil pump
    Gates Kevlar timing belt
    Tomei aluminum timing belt guide
    KillerB Motorsport Ultimate Oil Pickup
    APS 70mm cold air intake
    APS FMIC (charge pipes wrapped with DEI Reflect-A-Gold)
    TurboSmart Kompact BPV
    Perrin 3" turbo inlet
    IAG 8mm phenolic spacers
    IAG TGV deletes
    Cobb 1300cc stainless injectors
    Radium fuel rails w/ pulse dampers
    AeroQuip Startlite fuel hose (no stock fuel lines left in engine bay) plumbed in series
    Radium adjustable FPR
    Walbro 255lph fuel pump
    The turbocharger setup is Killer B's "Spoolinator" design:
    Garrett GTX 3071r turbocharger with TiAL v-band turbine housing (ceramic coated)
    Killer B Holy Header & up-pipe (ceramic coated & wrapped with DEI Titanium)
    TiAL 38mm EWG w/ Killer B dump tube
    Killer B v-band downpipe (ceramoc coated & wrapped with DEI Titanium)
    Tomei Expreme Ti catback
    Cobb 3-port EBCS
    IAG Comp-series AOS
    Koyo radiator w/ Gates hoses
    GrimmSpeed lightweight crankshaft pulley
    Killer B upper coolant reservoir
    Chassis & Suspension
    Group N motor mounts, pitch stop mount, trans mount
    Kartboy short throw shift w/ front & rear bushings and Turn-In Concepts Super Shift set (all bushings from shifter to trans)
    Whiteline transmission crossmember bushings, outrigger bushings, rear subframe lockdown bolts
    AST 4200 coilovers w/ Mooresport front camber plates & Ground Control rear camber plates
    Eibach rear camber bolts
    Whiteline sway bars front & rear with adjustable endlinks
    Whiteline roll center/bump steer kit
    Whiteline steering rack bushings
    Oswald Performance front subframe
    Welded-in NASA-spec 6-point roll cage
    Driveline, Brakes, Wheels, Tires
    Competition Clutch stage 2 clutch & lightweight flywheel
    5x114.3 hubs & knuckles conversion (them wheel bearings, yo)
    Enkei 17x9.5 +38 RPF1s
    Dunlop Direzza Z1 StarSpecs in 265/35/17 (fenders rolled)
    DBA 4000 series T3 slotted rotors
    EBC Bluestuff brake pads
    StopTech stainless brake lines
    GrimmSpeed master cylinder brace
    Motul RBF600 brake fluid
    Exterior
    VIS Tracer carbon hood
    INGS+1 aero kit (genuine, not knock-off)
    Beatrush rear tow hook
    APR GTC-300 spoiler
    06/07 rear tail light conversion
    Hella supertones
    GrimmSpeed battery tie-down
    Killer B belt cover
    Interior
    Corbeau FX1 Pro fixed back seats
    Corbeau 5-point cam-lock harnesses
    Defi Red Racer boost, oil pressure, oil temp, and EGT gauges
    AEM UEGO wideband gauge
    Zeitronix ethanol content analyzer & gauge (gauge not currently hooked up)
    Silky21L, jubella2, JuStaWRX and 2 others like this.
  2. BadlandsRacer
    Bump! Open to offers on this car.
  3. BadlandsRacer
    bump
  4. BadlandsRacer
    bump, let's get this sold already
  5. tangledupinblu
    This thing looks amazing! GLWS, that's alot of goodies in there for someone to inherit!!
  6. BadlandsRacer
    Bump. I'd like to get this sold, someone make me an offer.
  7. tangledupinblu
    Just curious, but how many miles are on the built motor/chassis/trans/etc?
    ScoobySnack likes this.
  8. BadlandsRacer
    Apparently I can't edit the original post to lower the price? Dropping the price to 15k, I want this car gone please.
  9. BadlandsRacer
    Didn't see this for some reason, but the chassis and trans have ~80k on them, the engine ~15k. Not at work right now so not able to look at the odo.
  10. tangledupinblu
    Also didn't notice above...but what kind of numbers is this thing putting to the wheels right now?
  11. BadlandsRacer
    Unknown. Previously hit 344/349 on a Mustang dyno on a Blouch 18g-XT. After we got away from as much autocross and more into road racing, realized the car was lacking in power, especially for the BIR long course. Ended up switching to a Killer B Spoolinator setup with the GTX3071r, some of Cobb's new stainless-core 1300cc injectors, and an all-new fuel system, to provide the power the little 18g couldn't. It's still on a base map for that setup, has not been fully tuned OR dyno'd since the changes.
  12. BadlandsRacer
    I'd definitely like to get this sold sooner rather than later. I have it advertised on Facebook for $14,000, MN Subaru will not let me edit the original post to the change the price.
  13. tangledupinblu
    I'll take care of that for you!
  14. BadlandsRacer
    My thanks!
  15. grinsler
    grinsler Member
    Not sure if this was ever updated. Did this car sell?
