2013 BRZ Build Thread (Previously Next Upgrade)
Discussion in 'Modifications And Maintenance' started by Kneel Weiß, Feb 25, 2014.
  1. tangledupinblu
    You want to see what he's flashing for sure Kneel! Jussayin
    tehfuzz and Kneel Weiß like this.
  2. Kneel Weiß
    Kneel Weiß FUMP BDI
  3. idget
  4. Kneel Weiß
    Kneel Weiß FUMP BDI
  5. tangledupinblu
    I put the ass in flassh
  6. derp
    what does that even mean
  7. TMF
    Ps, TRD springs are only $200 new and work with stock struts! Anyway, hope she is running in tip top shape soon... Monitor everything, but enjoy!
  8. derp
    Thisssssssss
  9. Kneel Weiß
    Kneel Weiß FUMP BDI
    Got the first leak! Thankfully not super bad. Leaked from the bottom of those damn banjo bolts on the oil cooler. Dicks...
  10. JasonoJordan
    Should of converted it to jic when you had the chance
  11. tangledupinblu
    Er mah gerd, now you own a Subaru!
    tehfuzz likes this.
  12. Kneel Weiß
    Kneel Weiß FUMP BDI
    Everything is buttoned back down and set. Haroo.
  13. EricS
    EricS Nooberator
    So is it working now? How does it drive? Don't leave us hanging dude! ;)
    Kneel Weiß likes this.
  14. derp
    It's a Subaru so it's broken
    Kneel Weiß and tehfuzz like this.
  15. tehfuzz
    tehfuzz Well-Known Member
    Fixed.
    Kneel Weiß, EricS and derp like this.
  16. Kneel Weiß
    Kneel Weiß FUMP BDI
    Works now. Good fun for sure.
  17. Kneel Weiß
    Kneel Weiß FUMP BDI
    Ha, I'll dig up this relic of a post.
    For those who don't already know, my car is 100% mine. No more bank.
    Just placed an order for two new Enkei RPF1s to square out the car. In the next month I'll be ordering an Eiback lowering kit with sway bars and bushings. And new tires when I get home.
    Phew.
  18. tangledupinblu
    GrawvyRobber and Kneel Weiß like this.
  19. derp
    Bout goddamn time you figure that monster truck out
  20. Kneel Weiß
    Kneel Weiß FUMP BDI
    I should lift it, just for you. With 14" wheels and stretched boihole tires. You'll love it! It'll be dope!
    Nhibbs likes this.
  21. tangledupinblu
    That sounds so IMG_0883.JPG !!
    Nhibbs and Krazylegz1485 like this.
  22. Kneel Weiß
    Kneel Weiß FUMP BDI
    Derpery?
  23. derp
    I'll derpery you
  24. Kneel Weiß
    Kneel Weiß FUMP BDI
    Aw, You miss me.
  25. derp
    My dick misses you
    Kneel Weiß and tangledupinblu like this.
  26. TMF
    Congrats! Always nice to be debt free.
    FYI, I haven't posted the stuff anywhere yet, but I'm going to be selling my TRD lowering springs and front and rear sway bars (includes reinforcement brackets and bushings)...$350? I'll also likely be selling my front and rear whiteline adjustable endlinks...$140. Everything is used but in good condition.
    Hit me up if you're interested!
  27. JasonoJordan
    Whats the reasoning for dumping all the gear?
  28. TMF
    Class changes for autox...there is a new spec class for the 13-16 FRS/BRZ for next year that requires running specific parts. I'm planning on jumping to that class, therefore need to sell all of my old stuff!
    JasonoJordan likes this.
  29. derp
    such as?
  30. TMF
  31. Nhibbs
    Nhibbs Well-Known Member
    That is a cool idea. It doesn't spec a tire, just a size and treadwear. There are a lot of "200 treadwear" tires that are actually a lot softer and 225 tires that are actually wider, I wonder if they will eventually pick a specific tire.
    Can you choose any brake pads/fluid? Or literally everything except the SCCA spec suspension stuff has to be stock?
  32. TMF
    Its all in the rules that I posted ;)
    There will in fact be a spec tire, but the specific tire is still "TBD". The annoying thing about the spec class, is that the SCCA is closely working with TireRack on this deal (you can actually select "SCCA SSC spec" as your vehicle on Tire Rack, and it will only show you eligible parts for the class when you search), and I think TireRack might be trying to steer towards a specific tire and/or tire manufacturers are throwing up deals to try to get the spec tire. I think the main concern is finding a tire manufacturer that can fully supply the demand for the tire.
    Brake pads/fluid are unrestricted. There are some other minor restrictions/guidelines (e.g. lug nuts/wheels studs can be changed, the catback is unrestricted given that it weighs at least 18 lbs and isn't a straightpipe, etc), but otherwise unless the rules say the modification/part is allowed, it has to be stock.
    Beside creating a class with a level playing field (which to me is awesome), it also fills in a nice gap between the "street" class (which is basically completely stock, except for struts and 1 sway bar) and the "street touring" class (which to get to full prep, easily costs $10-12k in modifications...and then your car is miserable to drive on the street). I was debating selling the FRS to get something else, but with this new class option, it will restore the things I wanted out of this car (namely better handling without spending $10-12k).
