245's slow me down quite a bit...
Discussion in 'Off-Topic' started by Sogonerg, Mar 20, 2007.
  1. Sogonerg
    Sogonerg Anteater
    after getting my tires (245/40/18) on my car...First time today that I really taken it out for a drive...Did a few 1st and 2nd redline pulls shut down around 60-65mph...Just to see a difference and man, I've slowed down enough that it is noticeable from 225 to 245...Grips great, but the car seems slower from dig.
    I need to definately get a bigger turbo to get that thing going...I knew it would slow me down from dig, but man I didn't think it was that obvious...or maybe I'm getting to use to my car that the VF34 isn't as quick when I first got it... After getting use to the increase in HP/TQ from stock it was a huge difference, but now it feels stock again lol...
  2. AspitFire
    you dont think those big ass brakes helped the slow down? :)
  3. Sogonerg
    Sogonerg Anteater
    oh gosh yes...I've only driven the car 3-4 times since the brake upgrade...I'm still not use to it, especially when the rears aren't installed yet so the car dips forward a bit when I step on it...
  4. esperunit
    esperunit Well-Known Member
    might be more related to the fact that your wheel and tire package is now much heavier, as well as your much larger front rotors adding much more rotational weight.
  5. piddster
    Each pound of rotational mass added to the driveline is like 7-8lbs static mass.
    I noticed a huge difference in the added weight of the 6mt (~80lbs) and the turbo with said hardware. My brakes don't feel as badass as they used to:emo:
  6. Sogonerg
    Sogonerg Anteater
    Yea..I figured all that weight and larger rotors would be the cause...The car does handle and brake better that's for sure...Building my Drivetrain first before I bring PAIN!
  7. zapman
    zapman Well-Known Member
    the warmer temperatures don't help either.
  8. AWDimprezaL
    drive your car more
  9. Dream
    Your lack of driving skills dont help either.
  10. readymix
    Indeed, practice makes perfect. You might be able to open your front doors and fly faster than it rolls...at least with the wider tires, you'll be able to land safely...nice and cushy.
  11. 6MTizzle
    6MTizzle 2SLO
    and the lambo doors.
  12. Chin
    Chin Well-Known Member
    Don't worry, in no time you will have forgotten how much quicker it was. ;) You will learn to appreciate the grip more...
  13. Sogonerg
    Sogonerg Anteater
    haha...right on Chin
  14. ShortytheFirefighter
    Bring Pain? Hell, we can all park our cars just as well as you can ;)
  15. Sogonerg
    Sogonerg Anteater
    alrighty...just wait folks, just wait...Let me get out of my grocery store first..haha
  16. Chux
    is the OD of the tires the same as before?
  17. Sogonerg
    Sogonerg Anteater
    nope it is wider...225 compared to 245
  18. ShortytheFirefighter
    And you fail... ;)
    Matt is asking you if the outer diameter is the same, not the width.
  19. Sogonerg
    Sogonerg Anteater
    oops...hehe then yes...18in. I thought OD meant original dimension (previous)...:biggrin: sorry Matt, thanks Brian...Also the bigger brake kit didn't help as far as the go...but definately help in stopping..
  20. mlgez
    mlgez Well-Known Member
    Not the rims, the tires...
    :crazy:
  21. Chux
    Ray...I'll make it easy for you....fill in the blank. You're old tires were 225/__r17s.
  22. ShortytheFirefighter
    Go slow Matt, you might hurt him...
    <-------has been in a cranky mood lately ;)
  23. Sogonerg
    Sogonerg Anteater
    18 w00t!
  24. mlgez
    Ummmm.... Ray you still missed it. 225/45r17 looking for the 45 like number there Ray.
    New ones 245/40/18
    Old ones 225/??/??
    :roll:
    :biggrin:
  25. readymix
    Man, conversations like this are the story of my day.
  26. Sogonerg
    Sogonerg Anteater
    Sh*t am I that out of it...thought I'm reading it right and my typing is not connecting with my brain...:crazy:
    225/40/18
    u know, I meant to type 40 but y I put 18 is a mystery...Plus my wife said I was talking in my sleep too last night...I need to proof read my post more often...
  27. Dizmal
    Dizmal Well-Known Member
    Haha
    At least you always take it in good stride, Ray
  28. wall of tvs
    Well then your new tires have a larger circumference and you have an effectively taller final drive. That's probably why it's slower from a dig now.
  29. Chux
    ding ding ding.
    according to this calc: http://www.subarubrat.com/Calc.htm
    your old tires were about 24" tall, and the new ones are 25.7". that means your car goes about 5" further per rotation than it did before....
    so yea, it'll accel slower. independent of the rotating mass issue. AND, taller tires means the weight of the tires is further away from the hub, which also means the tire has more angular momentum, even if it weighs the same.
    it has nothing to do with the tire width
  30. Sogonerg
    Sogonerg Anteater
    ding ding ding is right...BTW my ear drums is ringing too...
  31. wrxpeed
    wrxpeed CobraPeed
    I can't wait until my 315's come :biggrin: . Ordered some stickies for the rear, plant that ass. The stock 275's aren't cutting it anymore. Hope there isn't any major differences, the rim size is staying the same.
    Sorry for hijack.
  32. Sogonerg
    Sogonerg Anteater
    great Hi jack...:p
  33. wrxpeed
    wrxpeed CobraPeed
    hey, just stating that I need something to give me the grip to keep up with you AWDers off the line....
  34. Chux
    the sidewall height is what matters. I linked to a great gear and tire calculator above...punch in your tire dimensions and see if the OD changes much...then you can use those numbers to find the rpm differences at speed, etc.
  35. Chin
    Just to poke and prod a bit....yes, it has all to do with the width...the sidewall and the rim diameter didn't change, the width did. :p 40% of 215 != 40% of 245! :rockwoot:
    Muhahaha
  36. 1meanrex
    1meanrex Well-Known Member
    ray, if you dont mind me asking do you rub at all with the 245's.
  37. Chux
    come again?
    215*.4=86
    245*.4=98
    AND the rim diameter did change.
    my point was that if he had been going from 215/50r17, the change would not be nearly as obvious, because the OD would be virtually the same. obviously, there'd still be the weight issue....
  38. wall of tvs
    Uh, no the rim size didn't change.
  39. wall of tvs
    and why is this thread still alive?
    lol.
  40. Vector
    Vector Rally Organizer
    If he's rubbing with the 245's I hope he's dooing it somewhere private. I'd hate to walk in on that...
  41. ShortytheFirefighter
    Didn't he go from 17's to 18's?
  42. esperunit
    nope, both 18s just changed width and offset.
  43. ShortytheFirefighter
    My bad, I could've sworn his Rotas were 17s. Of course, this is Ray...17's wouldn't be bling enough.
  44. Chux
    heh heh.....fooled me too....[​IMG]
    so the OD of the tire only changes by less than an inch.
  45. Sogonerg
    Sogonerg Anteater
    Fronts are fine it is the Rears that rub, but not all the time tighter turns well rub and anyone in the backseat...and I have about an 1in drop...also with an offset of +44 with 8.5
