'89 4EAT XT6
Discussion in 'FS: Cars, Motorcycles, Boats' started by Chux, Dec 22, 2012.
  1. Chux
    Independence, MN
    I don't know, I have very little interest in this car. It would make a respectable rallyX car, but the fact of the matter, is I'm not sure I'd trust this car to make the trip to an event from Duluth, beat on it all day, and get me home. So then I'm borrowing a truck and trailer, and....well........bleh
    The good: Strong running ER27, Less than 150k miles IIRC.
    4EAT in great shape
    KYB GR2s all around (I bought the rears new, fronts were used but in decent shape), WRX springs in front, Eibach 250 lb/in in rear
    EJ front knuckles/axles ('92 Legacy L FWD, to be exact)
    Ver 1 WRX front brakes (same size as Turbo legacy, 2.5 RS etc. Probably same pads as early t-leg)
    Brand new Beck/Arnley Nissan 200SX rear calipers (Just installed a couple weeks ago, for rear ebrake conversion)
    New Bosch plug wires, NGK V-power plugs, Beck/Arnley 02 sensor, and starter brushes all installed shortly before the accident
    A LOT of spare parts. Like, it will take me some time to gather it all up, and more than will probably fit in the car. Power steering pump (no brushes), engine sensors, lots of interior trim, I can't even begin to list. The car came with a few large containers full of spares when I bought it, and I've parted out a car since then....
    Dash trim is in great shape. Has aftemarket (off-brand, pretty crappy) CD deck with USB/SD slots for MP3 playing. Has the correct dash kit, didn't come with instructions, so the outermost trim piece isn't held on correctly....not sure what's up there.
    The not-so-good: It's been driven less than a mile in 3.5 years. Surface rust on pulleys, old oil (Mobil1 Synthetic, though), gas tank is and has been mostly empty.
    A mouse moved in for a bit during that time. The glove box is full of chewed up insulation, and the blower motor is ruined (will include a new one).
    The passenger side rear taillight housing is not sealed to the body, so the trunk gets some moisture in it. Bottom of that quarter is rusted through, carpet is pretty skanky, and all the cardboard pieces in the trunk have long since been tossed.
    It was broken into before I got it. Only evidence that remains is the door handles (yes, BOTH of them) were replaced, and have been spray painted. Also, the metal around them is slightly munched. Not too bad, but evident
    Can't seem to find the lower half of the airbox.... :facepalm:
    No ebrake. XT6 handle and cables still installed (Ziptied to the front swaybar....). Will include Legacy handle and cables that I used in my Loyale wagon for rear handbrake.
    Rear sway bar not installed.
    Will come with 15" Legacy steelies with worn out (but holding air) all-seasons.
    The bad: It's been crashed at least 3 times. When I got it, both rear quarter panels had been repaired. Cracked/peeling bondo on one, and the inside of the other quarter is red, and the places where it was welded on are beginning to bubble.
    Had someone pull out in front of me in August of 2009, I got totally screwed, and couldn't get a dime from the woman who did it. Radiator support was pretty munched, passenger side frame rail is slightly bent just in front of the engine crossmember. I fixed it with a high-lift jack and hammer and the body panels off my '88 XT6 that I parted out. The bottoms of the fenders are rusted off in the back, so they're not really attached, and nothing lines up very well. Hood hinges had to be modified to turn the hood off to one side to get it to line up correctly. Passenger side headlight cannot open entirely as it sits, it's set back significantly compared to the hood and such, and hits the hood before up completely.
    Pics...
    Just over 4 years ago, shortly after I bought it. You can see the rear quarter damage:
    New parts that went into it that winter. Rear shocks, springs, plugs wires, and 02 sensor
    Crash, August of 2009
    Kink in the frame rail. But it's in front of all suspension pickups
    How it looks now
    All these body panels are bolted on tight, and hood is latched....
    I would definitely trailer it pretty much anywhere. As it will need some TLC before it would be a reliable DD. But it has started every time I've needed it to (as long as I remember hook up the MAF :p ). Comes up to temperature and the coolant system doesn't leak
    Looking for $1,000. Pretty firm on that, but possibly open to trades. Would definitely trade for some new 315/75r16 Mud-terrain tires.
  2. Chux
    Independence, MN
    Buuuump
    I was doing some other work outside today so I checked the mileage....116,900...
    Car will also include a set of 4 slightly used Hankook Rally tires with no wheels, ~205/65r15
  3. Chux
    Independence, MN
    Bump. Started right up today to move it.
    Decided it will not include the rally tires at that price. But seriously, there's $400 in Power Steering pumps here (these electronically powered hydraulic pumps are very common for hot rods and rock crawlers)....
  4. Chux
    Independence, MN
    Oh yea, and I could include a Part-time 4WD Hi-lo 5MT transmission. With starter, rear diff, flywheel, and crossmember. Most of the parts needed for the conversion (should just need pedal box and shift linkage)
  5. NastyLeggySS
    Isanti
    Rally tires sold seperately?
  6. Chux
    Independence, MN
    No, I want to hang onto those. I'll be rallycrossing something, even if it isn't this.
    Leviathan likes this.
  7. Chux
    Independence, MN
    Another bump
