93 Impreza AWD 5 Spd drivetrain, 1.8L motor (new oil pan, timing kit, water pump, timing covers), 5 spd trans in great shape, all axles and driveshaft, rear diff (still in the car, text drive before you buy. only selling because i'm doing a Version IV STi swap) - $800/obo Version IV STi headlights - 93 Impreza front axle (will work on others), needs outer cv boot - $15 93-96 Impreza Pass headlight - $25 Rear drum brake setup off 93 impreza (trailing arms, hubs, e-brake cables; all complete, took out to do wrx brake conversion) - $50 Stock suspension off 93 impreza (little worn, struts, springs, top hats (cept rear) all assembled, pulled to do wrx suspension swap) - $30 Washer fluid reservoir (repaired crack with jb weld, holds water) - $10 Fog light brackets - $20 Front mudflaps - $20 Sidemarkers - $20 99+ pass turn signal - $10 WRX rear tophats - $30 WRX rear seat - $50
