93 Octane
Discussion in 'Off-Topic' started by Scooby02, Nov 20, 2007.
  1. Scooby02
    Scooby02 Well-Known Member
    Not sure if this is a big deal or not. Since I havent seen 93 octane a lot around here. I stopped at a Bp down in Savage? on 13 (two buildings from Buffalo Tap) and they had 93. There is another Bp a little bigger about a block from there but never stopped there to see what they have. Just thought I would share since all I ever see is 91 and 92 octane.
    Dave
  2. Hallywood
    Hallywood Well-Known Member
    thanks! It's always nice to see that some stations still carry it
  3. Soupboy
    Soupboy Well-Known Member
    Seems like the winter blends have crept into most tanks now. I've seen my MPG drop a bit without any change in driving behavior.
  4. Taras
    Taras BANNED
    yeah I have noticed decline in mpg too. I am thinking about putting like 14 gal of 92 and a gal of 100 octane once in a while. My iam is still at 15.
  5. hella_sti
    hella_sti Well-Known Member
    they oxyganate the gas during the winter, thus the mileage change.
  6. Scuba Steve
    ^^^yeah, I recently learned if I don't add a bottle of stp octane booster to my tank each fill i get knock at wot. :eek4:
  7. stypert10
    stypert10 Well-Known Member
    There's a Holiday station in Fridley off of Central and Moore Lake (1 block from 694) that has 93 octane.
  8. wall of tvs
    holiday 93 sucks balls
  9. Scooby02
    doesnt holiday just suck balls no matter what? :)
  10. FuJi K
    so are they going to touch my non-oxy stations or not??
  11. Scooby02
    only yours Fuji!
  12. wall of tvs
    There's nothing better about non-oxy gas.
    The only benefit is if you are at 100% injector duty cycles since you will have to flow slightly less fuel with non-oxy.
  13. stypert10
    i found that out after i put in some holiday fuel a while back.
  14. demong
    demong Well-Known Member
    Where are the non- oxy stations??
    Do you think that I need another stage 2 performance reflash for the winter to go along with the fuel change?
  15. Scuba Steve
    mobil in EP has non-oxy.
  16. briancustoms
    All we had in Virginia Beach was 93 for high octane, I noticed that right when I moved here that we get the cheap stuff.
  17. gran0393
    gran0393 Well-Known Member
    whats the real diff between oxy and non oxy?
  18. Hallywood
  19. Scuba Steve
    "Oxygenated gasoline" is a mixture of conventional gasoline and one or more combustible liquids which contain oxygen ("oxygenates"). At present, ethanol is the most common oxygenate in the United States. The government requires gasoline to be oxygenated during the winter in areas that have a carbon monoxide pollution problem (cold weather and atmospheric inversions worsen carbon monoxide pollution). Oxygenated gasoline helps engines run leaner, which helps engines, particularly older engines, produce less carbon monoxide.
  20. WRX1
    Don't forget about the big bump in improved milage.:biggrin:
  21. AWDimprezaL
    that would explain why with my stock injectors my car ran best on non oxy
  22. SubeN'Siren
    SubeN'Siren Well-Known Member
    And probably also why my car (bone stock 02 WRX) seems to make more power when I mix 20% E-85 in the tank.
  23. wall of tvs
    Yup. :)
