95 subaru impreza ej20g swapped/race car
Discussion in 'FS: Cars, Motorcycles, Boats' started by Ryze, Aug 11, 2013.
  1. Ryze
    Ryze Member
    Here it is. Hasnt been out much and is currently broken. Has at least one bad cylinder needs a rebuild. But I need to get to focusing on other things and not race car. This car was going to be an ice race car for the iira. Needs a cage and the engine rebuilt and it would be ready to go. Tires,spare parts, safety equipment timing equipment. I have it all.
    Details
    1995 impreza L
    Ej20g (from a jdm legacy) mileage unknown. Has atleast one cylinder that is bad. Probably ringlands in cyl. 4
    850cc injectors
    Big ebay topmount
    3" ebay down pipe.
    Megasquirt v3.0
    Aem wideband
    Grimmspeed aos
    Crappy foriegn oil psi. Water temp and ricer tach
    Tokico dspec adjustable struts with 04 sti springs
    Newer brakes
    4.11 transmission
    5 sets of rims 4 sets of tires. Including brand new studded ice tires and brand new cooper weather master snow tires
    2 sets of all seasons
    Necessary modifications for megasquirt. Sti 36-1-1 crank gear
    Coil pack and custom length spark plug wires for a 1.8
    Firewall cowl was cut for intercooler fitment
    Spare parts
    4.44 jdm v5 sti transmission with the center diff welded.
    Hydrolic pull style clutch 6puck with everything necessary to swap the car (pedals, cylinders, lines etc etc.)
    4.44 rear diff also welded
    04 sti strut take offs
    Front lower control arms
    2 radiators
    2 driveshafts
    Many extra axles
    Brake master cylinder and booster
    2 alternators and a starter
    Legacy steering column and wheel
    03 wrx turbo td04
    Stock 91 legacy gt turbo with elbow
    Front brake calipers etc etc
    Walbro 190 fuel pump
    Safety equipment
    Corbeau racing 5 pt harnesses (one is installed in the car already)
    Fire extinguisher
    Safety solutions triangle window nets
    Battery box
    Timing equipment needed
    Dbcom race time transmitter (this is needed for iira racing)
    Spare ej22t closed deck short block that has spun bearings. Need rebuild
    Complete running ej18 long block.
    I was gonna use the crank and rods out of the 1.8 for the 2.2 and put the 2.0 heads on it and put it back into the car. Would make a prettt sweet setup.
    Onto the pictures
    Please call me or text me 763 443 9064 at this time id like to sell everything together looking to get $5000
  2. Ryze
    Ryze Member
    All offers can be considered
