98-01 2.5RS and GD WRX parts for sale
Discussion in 'For Sale : Car Parts' started by Zombie, Jul 24, 2011.
  1. Zombie
    Zombie Well-Known Member
    Cleaning out the garage so I can get my WRX engine swap finished. Parts are located in South Minneapolis. All prices are OBO.
    1. '98 2.5RS driveshaft, good u joints. Very little rust. 175k miles. $10 SOLD
    2. Unknown year Injen cold air intake that was modified to fit a '99 2.5RS. Includes good MAF housing and sensor and 2 filters. $40 SOLD
    3. '98-01 Impreza radio bezel. $5 SOLD
    4. '97-01 Impreza clear corner and clear side marker lights. $65 or trade for good OEM amber lamps.
    5. '97-01 Impreza shifter surround and brand new leather shift boot. $15 SOLD
    6. 2005 Saab 9-2X Aero struts with 90k miles on them. Fits WRX (and is slightly stiffer than the same year WRX) Still in good working condition with no leaking seals. $65 for all 4.
    7. '99-01 2.5RS Gauge cluster. Came from a '99 2.5RS with 19X,XXX miles $50 SOLD
    Also for sale is a TD04 from a 2002 WRX. It has some pretty bad shaft play but didn't smoke at all and the car ran well prior to removal. $50 SOLD
    8. EJ205 Short block from my friend's wife's 2002 WRX auto. The car this is from was 100% stock and had 115k miles. This motor was pulled because of an out of spec valve lash adjustment on the passenger side head. Motor did not use oil and ran very well. Cross hatch is still excellent and there is no ridge at the top of the stroke. Motor has been kept clean and could be dropped right in. $375obo
    9. EJ205 heads. Came from the short block above. There are no signs of cracking at the typical areas. Cam journals are in good shape as well as the cams. One burnt valve (see red arrow) due to skipped valve lash maintenance. I would recommend a valve job service, decking, and setting the valve lash before installing. $250obo for both
    10. GC aluminum radiator. This is a no name aluminum radiator. Has been on the car for 10k miles and has held up great. $60
    11. GrimmSpeed 38mm V-band EWG kit with Tial 38mm MVS wastegate. This kit has approximately 10k miles on it. Everything fit great. Flanges are in good shape, etc. Sells for $580. I'd like $400.
    12. GrimmSpeed crossover pipe. 02-05/08+ WRX, ALL STi/LGT 10k miles on it. Everything fit great. Flanges are in good shape, etc. $100
    I'm also looking for a good condition OEM radiator for a bugeye WRX. Thanks!
  2. G_2.5rs
    G_2.5rs Well-Known Member
    pmed ya
  3. Ctracey218
    PM'd as well
  4. JasonoJordan
    On the radiator note ur better off aftermarket imo
  5. Grayguy
    Grayguy Well-Known Member
    If you still have them available, I'll take the radio bezel and shifter surround
  6. Ctracey218
    NO, MAX... They are coming to Duluth.. Just not your house ;)
  7. Grayguy
    I doubt you actually need them, yours probably are like 9/10 already, ours are like 2/10 lol
  8. AspitFire
    PM sent on the struts. I NEED THEM!
  9. 2.5RS
    2.5RS Well-Known Member
    i have an extra set of amber side marker...
  10. Zombie
    I should have specified but I am looking for the amber corner lamps.
    Also, the intake is sold.
  11. Zombie
    Pending sale of gauge cluster, shift surround and boot, clear corners and side markers, and radio bezel to Ctracey218
  12. Munky King
    Munky King Well-Known Member
    Interested in gauge cluster if it doesn't sell.
  13. Se7enrex
    Se7enrex Well-Known Member
    chad you noob, looking to ditch the current rad in the wrx? see if someone will trade?
  14. Ctracey218
    Money sent.
  15. Zombie
    gauge cluster, shift surround and boot, and radio bezel sold. clear corners still for sale.
  16. Zombie
    Everything is sold except the struts and the clear corners/sidemarkers
  17. Se7enrex
    buy my wilwoods, fit under some 15"s, only $460 (what i paid) and they ARE ALL WEATHERS as Todd from TCE told me
  18. Zombie
  19. Zombie
    Buyer backed out on the struts. So those are still for sale.
    Also available:
    Ford Escort Cosworth air oil separator with AN fittings and mount. This was from a rally car from the late 90s mounted to a 2.0L turbo Cosworth YBT. It is internally baffled like a Crawford AOS and has a drain that goes back to the sump. It should work well on a subaru but would need to be custom plumbed/mounted. Manufactured by Bailey Motorsports. $75
    6. Rear mount battery kit. Comes with 4 sections of 4 gauge wire. 2 shorter sections that go from the firewall to the interior cutoff switch (included) and then 2 sections that go back for a box in the trunk. All the ends have nice lugs on them. I never had starting problems with this setup. Running two 4 gauge wires is much easier to hide under carpeting, etc. This cost me over $60 to piece together using welding cable. I'll sell it for $25. SOLD
  20. putz
    putz Well-Known Member
    DUDE, i WANT THE TD04, and the battery trunk location kit, please mark as sold, I will pm you with my phone#
  21. Zombie
    battery kit and td04 sold!
  22. Zombie
    Mods, let me know if you want me to just start a new thread or not but I am adding a bunch of stuff.
    1. EJ205 Short block from my friend's wife's 2002 WRX auto. The car this is from was 100% stock and had 115k miles. This motor was pulled because of an out of spec valve lash adjustment on the passenger side head. Motor did not use oil and ran very well. Cross hatch is still excellent and there is no ridge at the top of the stroke. Motor has been kept clean and could be dropped right in. $375obo
    2. EJ205 heads. Came from the short block above. There are no signs of cracking at the typical areas. Cam journals are in good shape as well as the cams. One burnt valve (see red arrow) due to skipped valve lash maintenance. I would recommend a valve job service, decking, and setting the valve lash before installing. $250obo for both
    3. GC aluminum radiator. This is a no name aluminum radiator. Has been on the car for 10k miles and has held up great. $60
    4. GrimmSpeed 38mm V-band EWG kit with Tial 38mm MVS wastegate. This kit has approximately 10k miles on it. Everything fit great. Flanges are in good shape, etc. Sells for $580. I'd like $400.
    5. GrimmSpeed crossover pipe. 02-05/08+ WRX, ALL STi/LGT 10k miles on it. Everything fit great. Flanges are in good shape, etc. $100
    Thanks!
  23. badbennyb
    This thread works for me if it still works for you. Added the new goods to the first post.
