98 Subaru Outback Sport WRX swap $6,500 obo
Discussion in 'FS: Cars, Motorcycles, Boats' started by Ninja 4 Life, Jul 26, 2016.
  1. Ninja 4 Life
    Sadly I have to sell my car, due to my wife needing a new one. We are trying to clean up some space on our credit. So no, I cannot accept any trades. Looking to get $6,500 or best offer.
    The engine build and tune was done by Kevin at Garage Tuning. Water pump,timing belt, idlers, cam seals, clutch, and crank seal were replaced during the time of build. Re-tune was done by Nuke at NF Performance when the turbo was upgraded by the previous owner.
    The car has a swap sticker in the door jamb already by California BAR. This is not a wire merge job. It has a wrx wagon harness from front to rear. The car is clean title not salvaged and no rust.
    Mileage Body: Unknown
    Mileage Engine: 72,XXX as it is a daily driver
    Engine:
    2.1l
    3in Turbo Back Exhaust
    Walbro 255
    Kinogawa td06-18g
    Five*O EV-14 1000cc Injectors
    Grimmspeed Y-pipe
    Grimmspeed gold oil cap
    JDM STi TMIC
    Perrin short ram intake
    ACL Bearings
    ARP Studs
    Eagle Rods
    Mahle Pistons
    STi Crank Shaft
    STi Oil Pump
    Mishimoto OEM Radiator (put in 4,000 miles ago)
    Drivetrain:
    Motul Oil
    Wrx Transmission
    Wrx Rear Diff
    Wrx Drive Shaft
    Wrx Front and Rear Axles
    Suspension:
    Tien SS Coilovers
    27mm Whiteline Front Sway Bar
    24mm Whiteline Rear Sway Bar
    Front and Rear Whiteline Endlinks
    Front Genuine Sti Strut Bar (Red)
    Whiteline anti lift kit
    Whiteline KCA roll center kit
    Interior:
    Viper 5901 with Remote Start and Paging
    Greddy Defi Gauges (EGT, Boost, Oil Pressure)
    05 STi Front Seats
    JDM V5 STi steering wheel
    GD Wagon Entire Wire Harness
    GD Dash
    GD Cluster
    GD Center Console and Extended Armrest
    GD Entire HVAC Unit
    JDM red hazard switch
    Reupholstered Rear Seats
    2.5rs Door Cards
    Eclipse AVN726E Navigation
    Rockford Fosgate Power1000 5ch amp
    10" Kicker comp subwoofer
    4 Diamond Audio Speakers
    4 Diamond Audio Tweeters
    Exterior:
    V6 Grille
    Rear Spats
    STi front lip replica
    RS Front End Conversion
    JDM Taillights
    JDM Roof Rails
    2004 STI BBS Wheels
    Cooper Zeon RS3-A tires
    RS Sideskirts
    STi Replica Upper Spoiler
    Set of 17" steelies and Bridgestone Blizzaks
    Brakes:
    Wrx Rear Disc Conversion
    RS Front Brake Calipers and Rotors
    Steel Brake Lines
    Motul Brake Fluid
    Now for some bad:
    Right front axle boot is ripped and needs replacing.
    There is the occasional smell of gas. There is a hose behind the A/C compressor that needs replacing.
    The air/fuel gauge needs to be hooked up still.
    The washer fluid motor does not work.
    The windshield has a crack.
    The passenger rear coil-over has the Subaru knock to it. Do not have the cash to have it looked at, so I am not sure what is wrong.
  2. tangledupinblu
    Henry's old car! This thing is a beast! GLWS
    Jnguyen likes this.
  3. Ninja 4 Life
    She certainly is a fun car!
  4. Ninja 4 Life
    Sale pending.
  5. Ninja 4 Life
    Sold!
