'99 SOHC 2.2L heads/intake manifold/MAF
Discussion in 'For Sale : Car Parts' started by FuJi K, Feb 1, 2007.
  1. FuJi K
    $200
    These heads are off of my '99 Impreza L Sport Wagon. They are in great shape! I've replaced the leaking spark plug o-rings and are still perfect. They do NOT come with the cam sensor, you have to use yours.
    The ONLY this I altered are the splitters. They have been hand ported and knife edged. Everything else is STOCK. One exahust stud has been replaced on the driverside head for a new one. Approx miles on these are 114k miles. The cams can be used as CORE for those who want to regrind theres. Both intake manifold gaskets will remain on the heads.
    I also have the complete EJ22E intake manifold w/ engine harness and throttle body sensors. It's like...FULLY EQUIPPED; coilpack and fairly new plug wires included. Them sensors don't go for cheap. NOTE: I've took off the throttle body part where the cable slings onto. If you want, I can try to put it back together as much as possible. $180
    UNLESS you want the combo and I can do $300. I can throw in the '99 MAF too! it WORKS!
    LOCALL pickup or meet you somewhere
    Fuji
