About the Recall...
Discussion in 'General Subaru Discussion' started by TheWRX, Feb 18, 2006.
  1. TheWRX
    TheWRX Well-Known Member
    I don't know if this subject was brought up before or what...But I do understand that there is a recall for the WRXs, not sure which years it applies to but I know it does to mine which is an 02WRX. It's for the ABS system and I believe all what they are going to do is just replace it with a new unit. Also I do know that they are not calling it a "Recall", that there calling it some type of a campainge or somthing like that...So I just wanted to see if anyone had any info on it or already had it done, I do know it was out since August 2005 or around that time...so it's been out...Any informtion about this issue will be appricated...Thanks :)
    Mohd
  2. ShortytheFirefighter
    It's not really a recall, it's a campaign. It applies to any 2002-2003 WRX manual transmission model. It's a recalibrated ABS ECU that is supposed to help with the feeling of "no brakes" when braking on uneven or broken pavement. It's free to any owner of an 02-03 with a 5 speed. However, it doesn't apply if you have a modified braking system (ie Stainless lines, larger rotors, etc.), so you'll need a stock braking system to get it. I notice a little bit of a difference, but it's only on broken or uneven pavement. Otherwise you'll never notice a thing. Hope this helps!
  3. TheWRX
    Yeah. That's perfect, helps alot :D ...Thanks..
  4. snbrd4evr
    snbrd4evr Well-Known Member
    What about 01 RS's? My car does that all the freakin' time!
  5. 02blubru
    Is there a way to find out what recalls have been done to a car? ie: gas smell, break ECU
  6. ShortytheFirefighter
    Kelly, as far as I know there is no fix for the pre 02 Imprezas.
    02Blubru, if you talk to any Subaru service department, they can pull up your vehicle and see if there are any open recalls or campaigns that need to be done.
  7. Xcelor8
    Xcelor8 Well-Known Member
    What about my 04, my car does this too, doesn't sound near as bad as the 02-03 cars though.
  8. tbone
    tbone Well-Known Member
    I had one recall when they changing oil by BP morries dealer. They did it at the same time. They replace a gasket that supposed to leak in the future.
  9. AWDimprezaL
    yeah, headgaskets! all n/a SOHC/DOHC 2.5s blow them at some point in thier lives
