ABS Diagnostics and rear sensor connectors I found where the front abs sensor connectors are under the hood. Anyone know where the connectors for the back two are? Also the service manual refers to a diagnostics connector above the gas pedal some where. I looked under there and didn't see any connectors like the one described. Any one have a real picture showing the diagnostics connector? This is on a 99 RS by the way. Thanks.
You mean the OBD-II connector ? That's in a recess, south of the steering wheel, almost to the edge of the bottom of the dash, then left a bit. Stuart.
Not that one. There is suppose to another connector according to the service manual that is above the gas pedal. It should have two wires to ground and produce the ABS light blinkage.
