So last year the ac worked fine. First time I used it this year it started out blowing cold, then would blow hot for a while. It goes back and forth between hot and cold. I added about 10oz of a recharge kit and not much change. One thing I noticed is the clutch on the compressor never kicks off, but it kicks on and off in the winter when using the defroster. It's a 15wrx any ideas?
So might have figured this out. From my research 15+ it looked like Subaru was having issues with compressors, mainly the clutch. The air gap on the clutch get to big, you can take the clutch off and remove a shim and it seems to fix it.
