Acceleration Data - Any Interest?
Discussion in 'Modifications And Maintenance' started by rplumbo, Jan 18, 2007.
  1. rplumbo
    rplumbo Active Member
    Vadnais Heights, MN
    Is anyone interested in collecting acceleration data on their cars?
    I built up a 3 axis accelerometer board (from a sample I got at work) which will record X, Y and Z accelerations at 280Hz (280 samples/second). I tested it on my friend's car with some really interesting results. I was able to extract peak acceleration (m/s/s or Gs) through each gear and shift times too.
    In theory, we'd be able to extract shift points (in MPH) from the acceleration data, but I can't clean it up enough to make that work well enough (yet).
    The test car below is a Mitsubishi Lancer Evo 8. He had it tuned and dynoed at DB performance and it came in at 318whp (peak).
    What other data would be interesting to collect? I never hear too much about this statistic, and I figure it's not talked about much because it's hard to get or nobody cares.
    I can bring this to Firestone sometime if you guys want to measure your cars. You'll get some acceleration plots, and I'll get to ride in some fast Subarus. That's a good deal to me.
    Anyway, here's what I measured below.
    Reid
  2. rplumbo
    Vadnais Heights, MN
    Here's the plot.
  3. rplumbo
    Vadnais Heights, MN
    You can see pretty clearly where he shifts by the negative acceleration. You can also see where he lets off the gas in preparation for a shift. Also notice the oscillation after he gets back on the gas. You can feel this in the car too. I think it's from a bad/quick shift. It's a new clutch too, so that may have something to do with it.
    Braking acceleration was not great because it was snowy out. The ABS kicked in a few times. The acceleration through the gears was lacking a little too because the wheels would slip every now and then. This was done on wet pavement.
  4. Back Road Runner
    Oronoco/Rochester/Mankato
    It looks like a fun toy. I could be very useful...for accel, decel, cornering, whatever, maybe even for suspension if you measure verticle movement, maybe even independent front/back movement if you had two.
    What about compensating for body roll?
  5. Shibbs
    Wow. Another ECE geek like myself! haha. That's pretty sweet. Could prove to be some fun!
  6. powerlabs
    powerlabs New Member
    Daily driving 600RWHP somewhere in the world.
    ECUTEK Delta Dash does the same thing:
    Code:
    Time(s)	 RPM	 Speed(m/s)	 ChangeInDistance(m)	 Cumulative Distance(m)	 Acceleration(m/s^2)	 Accelerative Power(W)	 Drag Force(N)	 Drag Power(W)	 Wheel Power(W)	 Wheel Torque(Nm)
    0.83	2280	12.68	0.78	6.35	1.77	31405.1	61.9	784.2	32189.3	134.8
    0.89	2299.5	12.78	0.8	7.15	1.68	30125.4	62.9	804.3	30929.7	128.4
    0.95	2319	12.89	0.8	7.95	1.79	32232.7	64	825	33057.7	136.1
    1.02	2339.3	13.01	0.81	8.76	1.83	33299.2	65.1	846.9	34146.1	139.4
    1.08	2359	13.12	0.82	9.58	1.69	31009.5	66.2	868.5	31878.1	129
    1.14	2379.5	13.23	0.81	10.39	2	36981.2	67.4	891.3	37872.5	152
    1.2	2400	13.34	0.81	11.2	1.75	32608.7	68.5	914.6	33523.3	133.4
    1.26	2419.5	13.45	0.82	12.02	1.81	34014.9	69.7	937.1	34952	137.9
    1.32	2440.1	13.57	0.82	12.84	1.94	36924.4	70.9	961.2	37885.6	148.3
    1.38	2460.5	13.68	0.83	13.67	1.76	33638	72	985.4	34623.4	134.4
    1.44	2481.7	13.8	0.84	14.51	2.12	40909.7	73.3	1011.2	41920.9	161.3
    1.51	2503.5	13.92	0.85	15.36	1.86	36164.5	74.6	1038.1	37202.6	141.9
    1.57	2524.1	14.03	0.85	16.21	1.89	37057.1	75.8	1063.9	38121	144.2
    1.63	2545.5	14.15	0.88	17.09	1.91	37916.4	77.1	1091.1	39007.5	146.3
    1.69	2567.9	14.28	0.91	18	1.99	39831.4	78.5	1120.2	40951.7	152.3
    1.76	2591.4	14.41	0.92	18.92	2.1	42269.6	79.9	1151.3	43420.8	160
    1.82	2614.7	14.54	0.94	19.85	1.91	38867.6	81.4	1182.6	40050.2	146.3
    1.89	2638.7	14.67	0.95	20.81	2.17	44623.7	82.9	1215.4	45839.1	165.9
    1.95	2664.2	14.81	0.96	21.77	2.17	44894.6	84.5	1251	46145.6	165.4
    2.02	2689.3	14.95	0.97	22.74	2.1	44022.6	86.1	1286.7	45309.3	160.9
    2.08	2715.5	15.1	0.98	23.73	2.35	49680.8	87.7	1324.6	51005.4	179.4
    2.15	2741.2	15.24	0.99	24.72	2.03	43222.7	89.4	1362.6	44585.3	155.3
    2.21	2766.8	15.38	0.99	25.71	2.38	51358.9	91.1	1401.2	52760.2	182.1
    2.28	2793.8	15.53	0.99	26.7	2.31	50214.2	92.9	1442.7	51656.9	176.6
    2.34	2821.5	15.69	0.98	27.67	2.62	57593.2	94.7	1486	59079.2	200
    2.4	2849.2	15.84	0.96	28.63	2.42	53756	96.6	1530.2	55286.2	185.3
    2.46	2877.8	16	0.97	29.61	2.77	62077.4	98.5	1576.7	63654	211.2
    2.52	2908	16.17	0.98	30.59	2.74	61981.4	100.6	1626.9	63608.3	208.9
    2.58	2938.1	16.33	0.99	31.58	2.73	62432.6	102.7	1677.9	64110.5	208.4
    2.65	2970.1	16.51	1	32.59	3.09	71527.5	105	1733.3	73260.9	235.5
    2.71	3002.4	16.69	1.01	33.6	2.79	65152.6	107.3	1790.5	66943.1	212.9
    2.77	3035.3	16.87	1.03	34.63	3.19	75442.7	109.6	1850	77292.6	243.2
    2.83	3071.8	17.08	1.04	35.66	3.46	82680.6	112.3	1917.6	84598.2	263
    2.89	3107.4	17.28	1.06	36.72	2.95	71439.1	114.9	1985	73424.1	225.6
    2.95	3144.6	17.48	1.07	37.8	3.75	91726.4	117.7	2057.1	93783.5	284.8
    3.01	3183.7	17.7	1.07	38.87	3.37	83560.8	120.6	2134.8	85695.6	257
    3.07	3222.8	17.92	1.09	39.96	3.75	94006.9	123.6	2214.4	96221.3	285.1
    3.14	3262.9	18.14	1.1	41.06	3.55	90268.2	126.7	2298.1	92566.3	270.9
    3.2	3303.5	18.37	1.11	42.17	3.86	99128.4	129.9	2385.1	101513.5	293.4
    3.26	3346.5	18.6	1.13	43.3	3.96	103155.3	133.3	2479.3	105634.6	301.4
    3.32	3389.5	18.84	1.14	44.44	3.89	102582	136.7	2576.3	105158.3	296.3
    3.38	3435.4	19.1	1.16	45.6	4.47	119411.4	140.4	2682.3	122093.7	339.4
    3.44	3483.1	19.36	1.17	46.78	4.22	114384.4	144.4	2795.5	117180	321.3
    3.5	3530.1	19.63	1.19	47.97	4.34	119287.8	148.3	2910.2	122198	330.6
    3.56	3580.5	19.91	1.21	49.17	4.83	134642.7	152.5	3036.6	137679.3	367.2
    3.62	3631.5	20.19	1.24	50.41	4.35	123057.3	156.9	3168.2	126225.5	331.9
    3.69	3683.5	20.48	1.26	51.67	5.02	143973.1	161.5	3306.4	147279.5	381.8
    3.75	3737.3	20.78	1.26	52.93	4.77	138614.7	166.2	3453.3	142068	363
    3.81	3790.4	21.07	1.28	54.21	4.9	144488.9	171	3602.6	148091.5	373.1
    3.87	3843.9	21.37	1.3	55.5	4.84	144795.7	175.8	3757.3	148553	369
    3.93	3896.9	21.66	1.31	56.82	4.81	145788.5	180.7	3914.9	149703.4	366.8
    3.99	3948.2	21.95	1.33	58.15	4.53	139318.8	185.5	4071.6	143390.3	346.8
    4.05	4000	22.24	1.35	59.5	4.91	152739.6	190.4	4234.1	156973.7	374.7
    4.11	4053.1	22.53	1.37	60.87	4.75	149806.3	195.5	4404.8	154211.2	363.3
    4.18	4106	22.83	1.39	62.25	4.87	155726.1	200.6	4579.4	160305.5	372.8
    4.24	4157.8	23.12	1.4	63.66	4.57	147787.1	205.7	4755.2	152542.3	350.3
    4.3	4209	23.4	1.42	65.08	4.76	155841.6	210.8	4933.1	160774.7	364.8
    4.36	4259.3	23.68	1.46	66.53	4.29	142248.4	215.9	5112	147360.4	330.4
    4.42	4308.6	23.95	1.49	68.02	4.48	150346.8	220.9	5291.6	155638.4	344.9
    4.48	4360	24.24	1.49	69.51	4.76	161429.1	226.2	5483	166912.1	365.6
    4.54	4411.6	24.53	1.49	71	4.65	159649.7	231.6	5680.3	165329.9	357.9
    4.61	4463	24.81	1.51	72.51	4.71	163521.8	237	5881.2	169402.9	362.5
    4.67	4515.5	25.1	1.52	74.03	4.84	170095.8	242.6	6091	176186.8	372.6
    4.73	4566	25.38	1.54	75.57	4.35	154651.3	248.1	6297.6	160949	336.6
    4.79	4614.8	25.66	1.56	77.13	4.53	162543.5	253.4	6501.6	169045.1	349.8
    4.85	4663.1	25.92	1.58	78.71	4.27	154937.1	258.8	6708	161645.1	331
    4.91	4712.6	26.2	1.59	80.3	4.75	174183.8	264.3	6924.1	181107.9	367
    4.97	4764.5	26.49	1.61	81.91	4.7	174261.6	270.1	7155.4	181417	363.6
    5.03	4816	26.77	1.63	83.54	4.66	174591.4	276	7389.5	181980.9	360.8
    5.09	4868	27.06	1.64	85.18	4.81	182118.7	282	7631.5	189750.2	372.2
    5.16	4917.7	27.34	1.68	86.86	4.15	158668.4	287.8	7867.8	166536.2	323.4
    5.22	4966.9	27.61	1.72	88.58	4.61	178322.3	293.6	8106.4	186428.7	358.4
    5.28	5018.3	27.9	1.73	90.31	4.53	176748.2	299.7	8360.5	185108.7	352.2
    5.34	5067.5	28.17	1.73	92.05	4.32	170330.5	305.6	8608.8	178939.2	337.2
    5.4	5116.7	28.45	1.73	93.78	4.64	184834.6	311.5	8862.1	193696.7	361.5
    5.46	5166.1	28.72	1.75	95.52	4.35	174976.5	317.6	9121.3	184097.8	340.3
    5.53	5214.9	28.99	1.76	97.28	4.53	183680.2	323.6	9382.1	193062.2	353.5
    5.59	5263	29.26	1.78	99.06	4.24	173854.7	329.6	9644.5	183499.2	332.9
    5.65	5309.1	29.52	1.8	100.86	4.14	170931.5	335.4	9899.9	180831.4	325.3
    5.71	5356.3	29.78	1.81	102.67	4.46	185903.3	341.4	10166.5	196069.7	349.6
    5.77	5404.7	30.05	1.83	104.5	4.34	182709.6	347.6	10444.3	193153.9	341.3
    5.83	5454.2	30.32	1.84	106.34	4.67	198432.9	354	10734.2	209167.1	366.2
    5.89	5501	30.58	1.86	108.2	3.83	164002.7	360.1	11012.5	175015.2	303.8
    5.95	5544.1	30.82	1.88	110.08	4.03	173858.1	365.8	11273.8	185131.9	318.9
    6.01	5590	31.08	1.89	111.97	4.32	187812.6	371.8	11555.7	199368.3	340.6
    6.08	5636.1	31.33	1.9	113.87	4.1	179646.5	378	11844.5	191490.9	324.4
    6.14	5682.2	31.59	1.92	115.79	4.29	189812	384.2	12137.1	201949.1	339.4
    6.2	5728.1	31.85	1.94	117.73	4.07	181470.9	390.4	12433.7	193904.6	323.3
    6.26	5774.2	32.1	1.95	119.68	4.32	194374.7	396.7	12736.3	207110.9	342.5
    6.32	5819.8	32.36	1.97	121.65	3.98	180253.2	403	13040.3	193293.6	317.2
    6.38	5863.5	32.6	1.98	123.63	3.99	182257.8	409.1	13336.8	195594.6	318.5
    6.44	5906	32.83	2	125.63	3.74	171895.2	415.1	13628.6	185523.8	300
    6.5	5947	33.06	2.01	127.64	3.73	172579.5	420.9	13914.4	186493.9	299.5
    6.56	5988.5	33.29	2.03	129.67	3.84	178925.1	426.8	14208.1	193133.2	308
    6.63	6031.9	33.53	2.04	131.7	4.05	190212.5	432.9	14518.6	204731.1	324.1
    6.69	6075.2	33.78	2.08	133.78	3.76	177675.8	439.2	14834	192509.8	302.6
    6.75	6118.6	34.02	2.1	135.88	4.05	193055.7	445.5	15154.2	208210	325
    6.81	6161.1	34.25	2.09	137.96	3.67	176145.9	451.7	15471.9	191617.8	297
    6.87	6202.7	34.48	2.1	140.06	3.9	188118.9	457.8	15787.3	203906.2	313.9
    6.93	6244.2	34.71	2.11	142.18	3.66	178120.7	464	16106.7	194227.4	297
    6.99	6285.6	34.95	2.13	144.31	3.87	189420.5	470.1	16429.3	205849.8	312.7
    7.05	6327.9	35.18	2.14	146.45	3.81	187840.8	476.5	16762.6	204603.4	308.8
    7.12	6368.9	35.41	2.16	148.6	3.66	181267.2	482.7	17090.9	198358.1	297.4
    7.18	6409.9	35.64	2.17	150.77	3.81	189863.6	488.9	17423.1	207286.7	308.8
    7.24	6453.4	35.88	2.18	152.96	4.11	206527.3	495.6	17780.3	224307.6	331.9
    7.3	6495.9	36.11	2.2	155.16	3.62	183208.7	502.1	18133.9	201342.5	296
    7.36	6534.8	36.33	2.21	157.37	3.45	175468.2	508.2	18461.3	193929.5	283.4
    7.42	6571.5	36.53	2.25	159.62	3.16	161424.9	513.9	18773.9	180198.9	261.9
    7.48	6608.1	36.74	2.26	161.88	3.44	177011.4	519.6	19089.7	196101.1	283.4
    7.54	6645.7	36.95	2.25	164.13	3.41	176307.9	525.6	19417.7	195725.6	281.2
    7.61	6682.5	37.15	2.26	166.4	3.28	170828.9	531.4	19741.8	190570.8	272.3
    7.67	6718.5	37.35	2.28	168.67	3.28	171317.8	537.1	20063	191380.8	272
    7.73	6755.2	37.56	2.29	170.96	3.39	178341.7	543	20393	198734.7	280.9
    7.79	6794	37.77	2.3	173.26	3.68	194679.6	549.3	20747	215426.6	302.8
    7.85	6832.4	37.98	2.31	175.58	3.3	175541.1	555.5	21100.5	196641.5	274.8
    7.91	6866.5	38.17	2.33	177.9	2.91	155637	561.1	21418.3	177055.3	246.2
    7.97	6899.5	38.36	2.34	180.24	3.09	166159.1	566.5	21728.6	187887.7	260
    8.03	6936.6	38.56	2.35	182.59	3.66	197425.5	572.6	22080.9	219506.4	302.2
    8.09	6975.9	38.78	2.36	184.95	3.48	189108.9	579.1	22457.7	211566.6	289.6
    8.16	7013	38.99	2.4	187.36	3.21	175109.6	585.3	22818.7	197928.3	269.5
    8.22	7049.5	39.19	2.44	189.8	3.27	179383	591.4	23175.9	202559	274.4
    8.28	7085.6	39.39	2.46	192.26	3.17	174693.9	597.4	23534.6	198228.5	267.2
    8.34	7122.2	39.6	2.44	194.7	3.41	188948	603.6	23900.6	212848.6	285.4
    8.41	7156.4	39.79	2.48	197.18	2.7	150208.8	609.4	24246.9	174455.7	232.8
    8.47	7187.6	39.96	2.55	199.73	2.73	152633	614.8	24565.2	177198.2	235.4
    8.53	7220.4	40.14	2.56	202.29	2.97	167106.3	620.4	24902.8	192009.1	253.9
    8.6	7255.2	40.34	2.57	204.86	3.09	174611.8	626.4	25265.2	199877.1	263.1
    8.66	7291.4	40.54	2.56	207.41	3.26	185269.1	632.6	25644.7	210913.7	276.2
    8.72	7326.4	40.73	2.54	209.95	2.96	168893.9	638.7	26015.7	194909.7	254
    8.79	7358.1	40.91	2.55	212.5	2.68	153644.1	644.3	26355.2	179999.3	233.6
    8.85	7391	41.09	2.56	215.07	3.18	182954.4	650	26710.9	209665.3	270.9
    8.91	7425.3	41.28	2.57	217.64	2.92	168591.3	656.1	27084.2	195675.4	251.6
    8.97	7457.1	41.46	2.59	220.23	2.74	158756.2	661.7	27433.3	186189.5	238.4
    9.04	7486.3	41.62	2.62	222.85	2.41	140544.6	666.9	27757.2	168301.7	214.7
    9.1	7514.8	41.78	2.61	225.46	2.66	155329.1	672	28074.9	183404	233.1
    9.16	7542.7	41.93	2.56	228.01	2.43	142793.3	677	28389.4	171182.6	216.7
    9.22	7571	42.09	2.57	230.58	2.72	160392.4	682.1	28710.3	189102.7	238.5
    9.28	7601.4	42.26	2.58	233.16	2.8	165930.3	687.6	29057.1	194987.5	245
    (truncated because the post was too long)
  7. bummpy
    bummpy New Member
    nordeast
    Do you have that thing mounted to something or are you holding on your lap?
    You could get some weird dampening effects if you're holding on to it. Probably wouldn't be that much, but still.
    Doesn't the ecutek kind of piggyback onto the stock ecu. At least in the sense that it only has the stock sensors to read off of. I would say that a stand alone accelerometer would be a more accurate gauge of whats going on, rather than some sort of interpolated results from the factory ecu.
    Just my guess though, I don't know anything about ecutek.
    Edit:
    I just noticed that it was the ecutek (brand) delta dash (model). Which is probably one of those radar detector looking things that measures g-force/0-60/ 1/4 mile times etc. So never mind.
    I'd still probably wager that a stand anlone accelerometer would be better, but you can't really say that without knowing the specifics of either.
    Either way, carry on!
  8. powerlabs
    ECUTEK Delta Dash is a computer interface with your ECU. It monitors, displays and datalogs every single sensor, relay and output from your ECU. Every single one; it can tell you things as random as: Is the rear window defroster on or off? How many steps is the idle air control valve at at any given moment, etc etc.
    Provided that there is no wheel spin and your speedometer is accurate, the data should be perfectly accurate. With wheelspin of course the program will think you are accelerating faster than you really are. On a level road in 3rd gear (the way the test is normally performed) it is said to be within a % of what a dyno reports.
    Plus it doesn't just look at acceleration data... I can look at time vs rpm vs air fuel ratio vs ignition timing advance vs boost vs throttle position vs coolant temperature, etc etc etc... Very powerful tool; I wouldn't live without mine :)
    It also allows you to adjust idle rpm, ignition timing retard, and a couple of other things too.
  9. bikerwriter
    bikerwriter Well-Known Member
    St. Louis Park
    You can probably do something similar with the Enginuity logger as long as you log vehicle speed. It would give you time, just not g's.
  10. bummpy
    bummpy New Member
    nordeast
    Hey, I'm not doubting that as a useful tool. All I'm saying is that the outputs are only as good as the inputs are. I'm not sure of what kind of accelerometers are used in cars these days (airbag sensor? abs actuator?). All I'm saying is that if you use speed and time to calculate acceleration, it won't be as accurate as measuring acceleration with an accelerometer. The airbag sensor is probably more of an on/off threashold accelerometer, and the abs probably doesn't even use an accelerometer (I don't know what kind of systems they use).
    All I'm saying is that interprolated calculations will have more error than a calabrated accelerometer. And if the ecutek is drawing off of sensor data from the car, I'm just saying that I'm unaware of what the capabilities of factory accelerometers are.
  11. rplumbo
    Vadnais Heights, MN
    I double stick taped it to the center console. It held it quite rigidly. Damping would be a primary concern if we were trying to measure the vibration profile of the car (which we can do using an Fast Fourier Transform). 280Hz would be enough to capture vibe profiles up to roughly half that.
    The advantage of a dedicated accelerometer is it's a measure quantity, not a calculated one. The ECU unit is essentially doing calculus based on the ECU data. (Speed 2 - Speed 1) / (Time between speed 1 and speed 2).
    However, that's probably not that important in this situation because we really don't care about the absolute accuracy of the reading. Also, the output is not being fed in to anything else, so errors only compound once (in the calculus).
    I like the idea of an integrated ECU device. It'd probably be good enough. This has the advantage that it's portable and doesn't rely on anything else but me and my laptop.
    BTW, I'm not ECE....Aero. Engineering FTW! :)
    Reid
  12. T-REX5000
    T-REX5000 Well-Known Member
    St Louis Park, MN...uptown really
    Cool instrumentation, are you guys engineers?
  13. WagonsRock
    WagonsRock Well-Known Member
    Richfield
    Does anybody here have a G-tech meter or anything like it? I got one this fall from my girl friend. I had my doubts, and still do about good accuracy, but it is fun to mess around with.
    The G-tech uses an accelerometer and input read from the cigarette lighter to give you speed and acceleration numbers along with engine rpm. I can check 1/4 mile, 0-60, lateral G's, shift point, rpm vs. time, ...whole bunch of stuff. It also data logs your best runs and saves about 20 to 30 so that you can go back and review them when you get bored.
    Before it snowed, my friends and I were having a good time trying to best eachother's times on the meter. We would just put the meter in each car and see what it can do.
    I forgot to add, it does rough horsepower calculations after you plug in vehicle weight. I read that the baseline values you read off that are pretty bad, but it is good for checking the difference that different modifications make.
    There's my $0.02 on the topic.
  14. powerlabs
    Uh? Accelerometer? Dude I just explained that it runs off ECU data. I'm not going to repeat my post, re-read it if you didn't understand. This is exactly what ECUTEK uses to tune their cars. It comes off within one percent of dynos.
  15. bummpy
    bummpy New Member
    nordeast
    I understand. ecutek uses ecu data to calculate acceleration, that's fine and there's nothing wrong with that. I was just making sure you knew/understood the distinction between calculating and measuring acceleration.
    As you can see from graph posted above, acceleration is a pretty dynamic thing to measure.
    Let me illustrate what I'm trying to say so that you understand it.
    I can roughly (very roughly) calculate the acceleration of an sti if I know the trap speed and 1/4 time. I can use that to calculate the hp. I can then put that same sti on a dyno and measure it's actual hp. I can do this 5, 10, 500 times in a row. And then I can take hp(measured)/hp(actual) and average that over my sample group to get a calibration multiplier. And I bet you could probably do that and get results that are within whatever percentage of the actual dyno.
    There's nothing wrong with that whatsoever, if that's what you think I'm implying. I'm just stating that this is all thats going on. If you really look at the science of measurement, everything is treated this way. How accurate do you think a dyno is? Nothing that is measured is hard and fast. Theres always a statiscal element to it.
