Access Port-Cold Weather
Discussion in 'Modifications And Maintenance' started by Herger, Dec 7, 2005.
  1. Herger
    Herger Active Member
    For those with an AP, are you/have you had any problems duing cold (i.e. 10 below at least) weather. Same question to those with a custom tune (e.g. by Jorge). Thanks--steve
  2. readymix
    No problems yet for me in cold weather. I did have some last year, but that doesn't count...I doubt it had anything to do with the weather.
  3. Herger
    Stage 2?
  4. Cole
    Cole New Member
    No probs as of yet on Stg 2. No problems all last winter on 1.
  5. pbedroske
    pbedroske Well-Known Member
    Just installed mine last week. No problems as of yet. What kind of problems are you thinking about? elaborate...
  6. readymix
    Stage 2.5. Stray beyond the parameters and prepare to run like ass.
  7. 6MTizzle
    6MTizzle 2SLO
    Stg 2 and no problems yet this winter.
  8. silver03
    cold weather
    stage 2 and no trouble
  9. Justin
    Justin Well-Known Member
    no troubles here this winter or last
  10. MNAutomatic
    MNAutomatic New Member
    Nothing cept some raised boost levels cause of the colder air and higher exhaust temperatures in extreme cold and me not allowing enough time for warm up. Besides those, nothing
  11. krees23
    krees23 Well-Known Member
    Stage 2 no problems
  12. Herger
    Thanks for the replies.
    Running lean.
  13. Dream
    Why do you think your running lean? Ive never had any problems with my Accessport or maps.
  14. krees23
    If you're having problems, sometimes the moisture in your gas tank will freeze and could clog fuel filter. Try putting "dry gas" or equivelant into the tank if the symptoms indicate rough performance.
  15. DISCOPOPE
    DISCOPOPE Well-Known Member
    if you are lookin at logs you will see some leaning out due to boost creep.
    the colder charge and a restrictive wastegate could be your culprit
  16. Herger
    Sorry, I should have clarified earlier that I'm still stock but am considering an AP. I was wanting to find out if anyone was having problems because MN gets a lot colder than most other places.
