AEM boost gauge instal and not working!!!
Discussion in 'Modifications And Maintenance' started by BroCo, Sep 7, 2012.
  1. BroCo
    BroCo Moderator Staff Member
    I purchased a "pre-owned" AEM boost gauge from a member on here a few months ago. I didn't have a gauge pod for it until tonight. I wired up the gauge and tested it prior to tucking all of the wires away and it lit up and did the gauge sweep. Figured I had this thing dicked. I hooked up vacuum lines and got everything zip-tied into place and figured I'd go for a ride and see how she works. Well, it doesn't! it goes through its gauge sweep and then reads --- and doesn't read boost or vacuum. Right after that I go to google and find out that there has been a bad batch of sensors for these gauges. Anyone have any experience with this, I'd appreciate any help on this matter.
    This is why I hate buying used ****!!!!!!!
    Thanks in advance.
  2. ofspunk7
    Yeah used gauges always worries me as well. Did you double check for boost leaks? Mine read zero like yours when i had a leak.
  3. BroCo
    Mine doesn't even read zero, it reads --- I double checked for boost leaks and found none. I'm going to have to purchase a new MAP sensor for $58.00, now I will have as much invested into this as if I had pruchased it new.
  4. ofspunk7
    Want to buy my used gauge?
  5. BroCo
    I need to get this one to work or I'm out what I paid for it. It's not about the money, it's the principal behind it that pisses me off.
  6. ofspunk7
    I was just messing with you.
    BroCo likes this.
  7. BroCo
    It's not funny damnit! LOL
  8. ofspunk7
    I'll give you a discount on mine... I'll even toss in a copy of MW3 that won't disc error! ;)
    BroCo likes this.
  9. BroCo
    Now you are pissing me off! LOL...
    Nuke and ofspunk7 like this.
  10. BroCo
    Update: The new MAP sensor arrived today and low and behold the damn thing still reads ---. I am using the wires from my OEM boost gauge and hooked the boost line for the AEM sensor to the same "T" that my old gauge was hooked to. WTF! I'm stumped.
  11. ofspunk7
    Well assuming that the wires are good, then I would say your gauge is the problem and not the sensor. The only other thing I can think of is that it is setup wrong.
  12. BroCo
    The gauge has 4 wires, a hot and a ground and then two other wires that are used for data logging. Tonight I checked the hot and ground with a multi-meter and the black wire reads 12 volts and the ground is good. I re-connected everything and it still doesn't work. I pulled the boost hose off of the sensor to make sure there were no leaks, with the car running and the vacuum makes it stick to my finger. The only other thing I can think to do is find someone that has a functioning gauge and see if it works on my set-up.
    Could I have possibly gotten another bad sensor? I have 14 days to return it to the guy I bought it from.
  13. GiMp
    GiMp Well-Known Member
    Steve I have one in my car. If you wanna stop by after the dyno I can look at it. Im in crystal by 100
    BroCo likes this.
  14. BroCo
    That would be great Nick. PM me your # and I'll give you a call. Thank you!
  15. BroCo
    Thanks to Nick AKA Gimp for bringing a AEM Boost gauge to Dyno Days for me to test. Found out that my gauge is junk! Everything worked just fine on his new one. Just my luck!!!!
  16. ofspunk7
    Sucks man. So buying new from now on?
  17. BroCo
    You damn right! You wanna buy a used AEM digital boost gauge? I know a guy who knows a guy that has one and it works great:rolleyes:
  18. ofspunk7
    $100? I have a working gauge, but i think two will make my car faster.
  19. BroCo
    SOLD!!!
    ofspunk7 likes this.
  20. BroCo
    I should see if I can turn it into a clock or something. What does one do with a non-functioning gauge?
  21. ofspunk7
    Some people have done that in their car. I know i have seen a thread on it.
  22. BroCo
    I think I saw something on NASIOC about that. I may have to look into it! That would look cool in a clock pod set-up.
