aeromotive eliminator fuel pump & controller have had this pump and controller for about 3 years. only used it for 3 months or 3000 miles and used it with a aeromotive fuel pump controller at all times. so its like new. pump works great. was keeping it around to use on my next build but will be using a mechanical pump instead. here is the description: Designed for EFI or carbureted street/strip applications, the Eliminator has a patent-pending dual chamber pumping mechanism. This continuous-duty pump supports more HP in a true street vehicle than any other pump and provides about 25% more flow at pressure compared to the A1000. # -12AN inlet port # -10AN outlet port # Fully-submersible for custom in-tank placement # Flow exceeds 800 lbs/hour @ 13.5 volts/45 psi # Flow exceeds 1000 lbs/hour @ 13.5 volts/8 psi # Fuel injected engines: Up to 1900 HP for naturally aspirated Up to 1400 HP for forced air induction Use regulator #027-13110 looking for 375$ also have the fuel pump controller. will add that for another $250 description: Deliver the correct voltage to the fuel pump at all times. Whether you're cruising or running wide-open throttle, Aeromotive's billet electric fuel pump controllers are able to sense engine rpms and deliver the correct voltage to the fuel pump(s). An adjustable knob lets you calibrate the desired rpm level, and an LED indicator confirms ignition hookup, verifies the energizing of the manual override circuit, and indicates the circuit is providing full voltage to the pump(s). Their housing is constructed from 6061-T651 billet aluminum and anodized in a beautiful, bright-dip red finish for good looks. Their low operating temperature allows mounting in any location, and they come complete with everything needed for installation.
i cant even image having a car that requires more fuel then the walbro can put out thats so insane lol
very nice setup! i used the same setup on my mustang for 3 years with no problems. you should post it on tcstangs also..
