Air Compressor
Discussion in 'Off-Topic' started by AspitFire, Mar 13, 2006.
  1. AspitFire
    Alright, i am going to go pick up some air tools. Anyone have any recommendations on what to get? how high of HP motor is ok, how many gal tank is adiquit? It is going to be used for minor car work, maybe some painting, and such. If anyone has any recomendations on what to get or know of any good deals out there let me know Thanks!
    I was thinking about something like this
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90234
  2. STIwannabe
    STIwannabe New Member
    I would suggest going a little bigger. Are you going to be using a DA sander or anything that requires more constant flow? Anything around 5hp should be enough for home use. I would recommend anything upwards of 20 gallon or more if you hate waiting for the compressor to recharge every 5 minutes.
  3. AspitFire
    mostyl for the impact gun, painting gun, and maybe a little grinding/polishing. I could always get a seperate tank if i find i need it, anouther 10 gallon tank is only $32 and 20-30 gallon compressors are around $390-600. Here is the tank i am talking about
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40057
    or can i not run those together? (parellel with each other) ??
  4. carbonfiber
    carbonfiber New Member
    that thing is crap, pull the trigger a few times and you'll have too refill the carp already.
  5. AspitFire
    thanks for being so detailed with your reasons...
  6. AWDimprezaL
    it wont be too bad, it will be running alot though, make sure you get an extension cord, and a super long hose, then you wont hafta deal with the noise ;)
  7. AspitFire
    stiwannabe and Erik, do you guys think this would be a much better buy
    link doesnt work
    Husky
    1.7 Running HP, 26-Gallon Air Compressor Kit
    The maintenance free compressor kit is perfect for completing many tasks around the home. You can inflate, paint, nail, clean up, and even perform automotive tasks like rotating your tires. The 1.7 running HP,26 Gal. air compressor features an easy to use and easy to read control panel with air tool matching chart. Air delivery is 5.6/3.8 SCFM @ 40/90 PSI. Maximum Pressure is 150 PSI. The kit includes 1/2 In. impact wrench, ratchet, air chisel with 3 bits, spray gun, grease gun, 50 Ft. air hose, 25 piece accessory kit and sockets.
    i know its a 1.7hp running, but its rated at 5.5 hp max
  8. kickin_81
    kickin_81 Well-Known Member
    ^^don't buy that. The CFM at 90 psi should be 5.5 or more SCFM to properly accomodate an impact wrench.
    As a matter of fact, I will be moving out of the house sometime in Spring/Summer and I won't have room for my Campbell-Hausfeld Air Compressor and tools. If you want to buy mine (belt driven) I can sell it to you for a reasonable price. It's been used no more than 3 working hours.
  9. AspitFire
    pic and price?
  10. STIwannabe
    I can vouch for Fong's equipment, it's in great shape and I'm sure he hardly ever touches it. If you haven't already bought impact sockets, stay away from the ones at Mills Fleet Farm, they're inexpensive but they can't hold impacts of 150lb/ftq or more.(I've busted a set already) It's better to pay a little more for good tools then to pay less and have the fustration of broken tools turn your quick installation into a scavenger hunt.
  11. kickin_81
  12. AspitFire
    sent you a pm Fong. No i havent bought anything yet.
