Air Intake Silencer
Discussion in 'Modifications And Maintenance' started by wings_23, May 30, 2007.
  1. wings_23
    wings_23 New Member
    I found a link on how to remove it, but do I have to plug anything after I remove it. And if I do what should I use?:eek4:
  2. AWDimprezaL
    no, maybe clear your ecu though. disconnect your batt step on the brake pedel, reconnect, drive.
  3. Bullwinkle
    I just left mine open. It's not like that factory "ram air" style does much anyway. Cold air from the fender ftw.
  4. webcrawlr
    webcrawlr Well-Known Member
    That's not exactly true. Someone did logging (on IWSTI) with it on/off and a SRI and found the coldest temps were had with the ram air funnel on. Conscientious was more fresh air being delivered.
  5. Bullwinkle
    Hrm. I left the funnel on, but removed the silencer, as I wold think that would be the best of both worlds. You got a link to that study?
  6. esperunit
    esperunit Well-Known Member
    The GPmoto elbow works better than removing the airbox altogether as the front ram air really does work, however it doesnt make as much noise as disconnecting the snorkus and just running a hole in the airbox.
  7. Scuba Steve
    ^^that may be true, but I wonder about volume of air with the RAM scoop in place. I think the air has too navigate up through the grill (some of it), up and past the hood, and then through the ram to the elbow, then on to the airbox. VS. into the airbox from the fender well.
  8. wings_23
    wings_23 New Member
    So after all this chatter, when I remove the silencer should I plug it or not. Will water get up in there or is it safe. I am not doing it for a "increase" of power, I just dont want to lose any.:eek3:
  9. Scuba Steve
    I've never had issues running straight from the fender well to the airbox. plugging the hole to the engine bay will look cleaner. Otherwise, just leave the RAM scoop in for the stock look.
    so, no....you don't have to plug the hole
