I have a collection of air tools that I need to sell. I haven't had access to an air compressor in years and need to offload these tools to make space in my box. 1/2" Snap-On Impact Wrench: $200 OBO SOLD http://rmn.craigslist.org/tls/3546647556.html 3/8" Blue Point Air Ratchet (Never Used): $150 OBO http://rmn.craigslist.org/tls/3546656515.html 1/4" Blue Point Air Ratchet (Never Used): $100 OBO SOLD http://rmn.craigslist.org/tls/3546661098.html Matco 90 degree angle Die Grinder kit (Used twice): $100 OBO SOLD http://rmn.craigslist.org/tls/3546670147.html All tools are in good condition and ready to use, the air ratchets had oil run through them and were immediately put away without being used. All items are in Rochester.
Model: IM6500 HP http://buy1.snapon.com/catalog/parts/pro_det.asp?Item_id=68323&group_id=17852 IM6500HP Features • 8-vane air motor provides faster motor start up and greater low torque output. • Reverse valve increases sealing surface and improves air management. • New muffler by-pass detent maintains exhaust position during heavy impacting. • Stronger valve spring prevents accidental movement of FORWARD/REVERSE lever. • Made in USA. Patented Cushion Grip • Field replaceable. • Ergonomically designed for the best hand fit. • Provides vibration and thermal isolation to help prevent operator fatigue. • Ribbed for positive tool control. Cushion Grip Trigger • Rounded comfort corners. • No pinch points. • “Soft Touch” featherability. • Patented tip valve design for greater control. Patented Power Boost Muffler Bypass System • Valve allows exhaust to be vented through the handle (closed) or above the trigger (open) for maximum performance. • New detent maintains selected operation. • Quiet operation in closed mode. • Great low pressure performance. • Made in the USA.
