airbag light
Discussion in 'Modifications And Maintenance' started by 1_sic_rex, Aug 30, 2007.
  1. 1_sic_rex
    1_sic_rex Well-Known Member
    Over the past month i have noticed this horrible clicking/clunking noise in my steering column when i turn the wheel. The airbag light has come on. I have taken the trim around the column of and found nothing loose.
    I have also taken the airbag of to see if there was a plug disconected, nothing. My horn no longer works and nor does my cruise control.
    Any toughts/suggestions???
  2. Yang
    Yang Well-Known Member
    same thing happen to me. Im to lazy to fix it. When you're talking about the steering column, is it the part thats in the car or outside. I hear cluncking on the outside when I steer to parallel park.
  3. 02blubru
    no horn and no cruise, I would check the fuse.
  4. 1_sic_rex
    Checked all the fuses.... A fuse still wouldnt explain the clicking noise INSIDE my column.
  5. John16V
    John16V Well-Known Member
    Clock's spring ;)
    Don't know if it is the same but on my old 98RS I had the same problem what you are describing.....go to nasioc and do a search.
    Good luck
  6. 1_sic_rex
    I tried searching a bunch of stuff... what should i search for
  7. John16V
  8. 1_sic_rex
    ^^^ great link.... how do i fix it?? can i just buy a "clock spring"?
  9. 1_sic_rex
    After reading through countless forums.... i fould how to fix it... My only question is, can i go tp the "stealership" and ask for a "clock spring?"
  10. subytek
    subytek Well-Known Member
    Yes, you can just ask for a clock spring, also known as a (roll conector). I bet you could ask someone at MTKA. Subaru and get a lower price, than at Rochester Subaru.
  11. 1_sic_rex
    I bet you are right.... Rochester subaru (clements sucks balls and has horrible customer service.) Ill check that out....
