Alignment at Tires Plus
Discussion in 'General Subaru Discussion' started by strangefamous, Jun 29, 2009.
  1. strangefamous
    MN Bugeye Mafia #002
    So I got an alignment at Tires Plus last week and just noticed that they Glued Weights on the inside of my wheels! Is this normal? On 1 of them it looks like they tried to glue some in different spots and failed, now there are random glue chunks everywhere. WTF!? :eek:
  2. AWDimprezaL
    Monticello.
    Glue? or are they stick-on...stick on weights are normal.
  3. jdm4you
    jdm4you New Member
    Da North Woods
    Mine are tape wights. I've never herd of them being glued on before.
  4. predavore
    predavore Well-Known Member
    Southern 'Burbs
    First problem... going to Tires Plus for anything. Second problem... Glue? WTF is right. Weights are either pounded on or have double-sided tape. Glue?
    Take it back and make them clean it up!
  5. readymix
    Eloh, El
    The "glue" marks are likely adhesive that is still left on the wheels from where they peeled the old weights on. The new ones aren't glued on, they are stuck on with adhesive tape.
  6. strangefamous
    I hear that man. I really only go to tires plus for allignments. Yeah I am pretty sure its glue. When I de-badged my car, the glue crap that is underneath the badges is the same stuff they used for the weights it seems like. I will have to bring it back and have them clean it up and find a new allignment place.
  7. AWDimprezaL
    Monticello.
    That isnt glue its tape. if they re-balanced your wheels too then that is your old tape weight residue.
  8. sneefy
    sneefy Well-Known Member
    QFT. Never, ever go to Tires Plus.
  9. austinpike
    austinpike Well-Known Member
    Oakdale, MN
    OK, step back. You said you had an alignment done. Did you pay for them to balance the wheels also? The balancing wouldn't automatically be part of the alignment. If they just did the alignment, and not a balance, they would not have messed with your wheel weights at all.
  10. strangefamous
    Nope. I didnt get a wheel balance at all. Hmmmm. I will have to give them a call. I wasnt charged for it so maybe they accidently did it HAH.
  11. goodhart
    goodhart Well-Known Member
    St. Cloud
    Maybe in the Twin Cities, Tires Plus in St. Cloud is probably the best tire/alignment shop in town.
  12. AWDimprezaL
    Monticello.
    IMO you are just seeing something that has been there for a while, and blaming the shop.
  13. strangefamous
    Nah, I clean my wheels all the time. This is the fisrt I have ever seen of these.
  14. GoldenRexasaurus[fc]
    GoldenRexasaurus[fc] New Member
    Twin Cities
    They should have used double sided tape as stated above
    Mine are double sided tape, had them replaced as well and I had to clean up the residue from the tape
    If its glue then thats a different story
  15. carl
    we gotta gooooo
    this sounds perfectly normal to me. stick on weights when removed will look like they were glued. they probably had trouble with balancing and had to relocate the weights
  16. piddster
    Boostonia
    LOL, no tire tech is going to take the time to clean the PSA (pressure sensitive adhesive) off your rim. If they are and the manager finds out, he would put an end to that.
    Tires Plus completely depends on the staff at that particular store. I've had bad luck with the TP in Duluth, but I trust the Savage store a lot. I have had several alignments, mount/dismounts, etc. I know the lead mechanic there.
    I've had small independant shops and even dealers mess stuff up before. Cripes, I had a dealer break three wheel studs on one wheel torquing it down.
  17. Aegis
    Female
    サイレントヒル
    There is nothing wrong with Tires Plus, it's just the idiots who work there. Carl is most likely right, they had to relocate the weights. Call them, I bet that's what they tell you.
    You can remove the adhesive residue. That's all it is, that crap usually looks like white glue when it dries.. or if it gets wet it can dry looking like super glue. Especially since they have to use the extremely sticky stuff. Touch it, if it's still sticky it's not any sort of super glue. All adhesives are glue though... but i'm sure it's really nothing to worry too much about. ;)
  18. sneefy
    Obvious stater states the obvious. :biggrin:
  19. Aegis
    Female
    サイレントヒル
    Well it seems to be extremely ridiculous to worry about something that is probably all over the wheels to begin with... find out why it's there and get rid of it. *shrug*
  20. piddster
    Boostonia
    A specialist once told me that adhesives are synthetic products, and glue is made from animals.
  21. predavore
    Southern 'Burbs
    Maybe my expectations are high. I'm treated very well when I go to Discount Tire in Rochester. :biggrin:
  22. carl
    we gotta gooooo
    which is why glue is good to eat and adhesives are not :laugh:
  23. AWDimprezaL
    Monticello.
    What about paste? that sht is delicious.
  24. sneefy
    Not a technical difference.
    Glue and adhesive are synonyms. Or at the very least, glue is in the family of adhesives. The terms are used interchangeably.
    Glue:
    3. any of various other solutions or preparations that can be used as adhesives.
    4. a substance that causes something to adhere, as glue or rubber cement.
    n. A substance, such as paste or cement, that provides or promotes adhesion.
    Originally made from animal products, for sure. Not much animal glue in use today.
    mmmmmm... delicious paste.
  25. TSTRBOY2004
    true.. see it all the time.. though I try to clean off the old tape after balancing...
  26. sneefy
    I'll agree with you here, for sure. That's the same reason I don't shop at Best Buy.
    I would say, however, that if a company routinely hires morons there is something wrong with more than just the employees.
  27. strangefamous
    Not to mention the prices at Best Buy are fail.
  28. sneefy
    Everything at Best Buy is fail. Especially Brad Anderson.
