Can some one please enlighten me regarding the exact purposes and theory behind Akli Injection? if so, it would be dramatically appreciated!
i got this out of nasioc FAQ's.... What is Water/Methanol Injection? Water Injection or Water Methanol Injection, is a process by which a mixture or water and Methanol are injected into the fuel/air mixture on the way to the combustion chamber. Water/Methanol Injection provides "Chemical Intercooling" inside the cylinder. By injecting water and methanol in a finely atomized spray, the water is able to evaporate under the high temps of a firing cylinder, and when the water evaporates, it takes heat with it. The methanol also has a cooling and octane boosting effect as it burns. How does water/methanol injection allow your engine to produce more power? The production of more power by a water/meth injected engine is not a by-product of the water/meth mixture alone. You must tune for it to get the most out of it. The evaporative effects of the water/meth mixture, plus the octane boost, allows you to run more advanced timing, and boost, thus increasing power. Methanol having the octane boosting effect, you can adjust your AFR's with tuning, and be able to run leaner AFR's than you would with just pump gas alone, with less risk of detonation, and also make more power. i got this out of nasioc FAQ's.... here is the whole thing for you people who want to read up on it http://forums.nasioc.com/forums/showthread.php?t=937176
ScoobyTodd had it in his STi and it produced well on the dyno tuned. On Stock Turbo he said he got 280awhp and 310awtq. That's with a mix 50/50, if it was straight meth it would be 20% higher at least..He was also on pump gas.
there is a bigger difference if you run 100% Meth rather than the 50/50. Justin's numbers is on a 50/50
(50-50%) from my 92 to my 92+meth map i instantly make ~20whp more on 1/2 psi more. boost... http://www.projectwrx.com/gallery/view_photo.php?set_albumName=album26&id=aag http://www.projectwrx.com/gallery/view_photo.php?set_albumName=album26&id=aay rich was running 100% on his tec setup and had really amazing results..... http://www.projectwrx.com/gallery/view_photo.php?set_albumName=album26&id=aax
I'm planning on mapping a 100%, 50/50, with 93 oct. and 110oct. That means I have to change my ecutek with an AP...*bastard, I should've waited for an APto begin with*....
