Aluminum polishing
Discussion in 'Modifications And Maintenance' started by Frogy, Jul 4, 2007.
  1. Frogy
    Frogy Well-Known Member
    Does anybody here polish aluminum, or know of someone who does. I am looking to polish my intercooler.
  2. carl
    i polished my intake manifold and turbo compressor housing before. an intercooler should not be a problem. how big is it?
  3. Frogy
    it's just a STI intercooler, I must be doing something wrong because it is a PITA.
  4. Paul Revere
    I know Scuba Steve just polished a wrx intercooler with what I don't know but it looks great!
  5. carl
    what's your process?
  6. Justin
    Justin Well-Known Member
    its easy...just time consuming
    flapper wheel, cross buff, buffing bob
  7. Frogy
    I started sanding the rough spots with 150, then smoothed that out with 400, the problem is that there are so many small surfaces that are so hard to reachespecially the tank pinch joints
  8. Frogy
    are you using a bench grinder?
  9. Justin
    no, hand held grinder
  10. Frogy
    where do you get your flapper wheel, cross buff and buffing bob, also what sort of compound do you use?
  11. angusracer
    angusracer Well-Known Member
    steel wool works...
  12. Justin
    www.wttool.com
    i forget what the compoung is, readymix would know.
  13. DankLeggie
    DankLeggie New Member
    Send it to JC Whitney
  14. Frogy
    Say what? honestly my main concern with polishing the IC is that the more it is handled the more chance there is to bend the fins.
