Amplifier Install
Discussion in 'Modifications And Maintenance' started by BlackDubRX, Sep 22, 2005.
  1. BlackDubRX
    BlackDubRX New Member
    Hey guys, I was looking at where to put the battery lead into the firewall, (I must be blind or something) but I can't find a place to do it. Anyone have any ideas? (03 WRX)
  2. Dynapar
    Orono, MN
    on mine there is alittle rubber seal covering a hole that is up and behind the gas/brake pedals. it comes out under the brake booster i believe. i would try and locate it form the inside first, it might be easier.
    good luck
  3. Justin
    Justin Well-Known Member
    St. Paul, MN
    there are two places that are easy to get to. The one that dynapar just mentioned...this one also has a piece of circular cut carpet covering it as well...so sometimes its hard to see. The second spot is on the passengers side, basically behind the glove box. If you look under the hood on the left side by your downpipe you will see a rubber hose, this is for a/c fluid i believe...well right by this hose is hole, of course has black rubber on it as well.
  4. BlackDubRX
    Thanks for the help guys, I ended up using the one under the pedals.
  5. DISCOPOPE
    DISCOPOPE Well-Known Member
    you can also run it through the driverside fenderwall.
    this involves jacking up and removing the driver forward wheel.
    take out the liner and it's pretty self explanitory where you shuld route it.
