Subject: Best Plans sometime go wrong. The bricklayer Possibly the funniest story in a long while. This is a bricklayer's >accident report, which was printed in the newsletter of the American >Insurance Journal. This is a true story. Had this guy died, he'd have >received a Darwin Award for sure. > > Dear Sir: "I am writing in response to your request for additional >information in Block 3 of the accident report form. I put "poor planning" >as the cause of my accident. You asked for a fuller explanation and I trust >the following details will be sufficient. > > I was alone on the roof of a new six-story building. When I >completed my work, I found that I had some bricks left over which, when >weighed later, were found to be slightly more than 500 lbs. Rather than >carry the bricks down by hand, I decided to lower them in a barrel by using >a pulley, which was attached to the side of the building on the sixth >floor. > > Securing the rope at ground level, I went up to the roof, swung the >barrel out and loaded the bricks into it. Then I went down and untied the >rope, holding it tightly to ensure a slow descent of the bricks. > > You will note in Block 11 of the accident report form, that I weigh >135 lbs > > Due to my surprise at being jerked off the ground so suddenly, I >lost my presence of mind and forgot to let go of the rope. Needless to >say, I proceeded at a rapid rate up the side of the building. > > In the vicinity of the third floor, I met the barrel, which was now >proceeding downward at an equally impressive speed. This explains the >fractured skull, minor abrasions and the broken collarbone, as listed in >section 3 of the accident report form. > > Slowed down slightly, I continued my rapid ascent, not stopping >until the fingers on my right hand were two knuckles deep into the pulley. >Fortunately by this time I had regained my presence of mind and was able >to hold tightly to the rope, in spite of beginning to experience a great >deal of pain. > > At approximately the same time, however, the barrel of bricks hit >the ground and the bottom fell out of the barrel. > > Now devoid of the weight of the bricks, that barrel weighed >approximately 50 lbs. > > I refer you again to my weight. > > As you can imagine, I began a rapid descent, down the side of the >building. In the vicinity of the third floor, I met the barrel coming up. >This accounts for the two fractured ankles, broken tooth and several >lacerations of my legs and lower body. > > Here my luck began to change slightly. The encounter with the barrel >seemed to slow me enough to lessen my injuries when I fell into the pile of >bricks and fortunately, only three vertebrae were cracked. > > I am sorry to report, however, as I lay there on the pile of! >bricks, in pain, unable to move, I again lost my composure and presence of >mind and let go of the rope and I lay there watching the empty barrel >beginning its journey back down onto me. This explains the two broken legs. > > I hope this answers your questions.
who gives a **** if they did... Mythbusters is a cool show.. I watch it all the time... I never saw them do this one... but then I dont give a ****.... so did they bust the fact that a guy could not get pulled up by a wheel barrow weighing 3 times his weight?? or the guy couldnt hold onto the rope?? or what???
i remember seeing that mythbusters but I don't recall what the outcome was. I thought they did acknowledge this actually happened
Confirmed. I would drop a barrel of bricks on each of you if it'd give me a chance. I'd expect no less from each of you. <----is going to start looking up more.
Mythbusters - Plausible - "Only by deliberately weakening the barrel and dropping it on a sharp edge were they able to get the barrel to drop its bricks"
