any stereo installers here?
Discussion in 'General Subaru Discussion' started by heavy hauler, Jan 31, 2010.
  1. heavy hauler
    heavy hauler New Member
    i want to upgrade my speakers and add a amp. on my 06 wrx
    any one experienced?
  2. Mr. Bill
    Mr. Bill New Member
    Do you already have an aftermarket headunit? I also assume you have all of the wiring needed for the install? I've done a lot of installs, never on a Subi though. Replacing speakers is almost always straight forward, and usually putting an amp in is as well. I'd lend a hand if you need one.
  3. errorcode3
    errorcode3 Member
    its actually extremely easy, especially if you already have the deck installed.
    install speakers with new wires
    run wires to amp
    run power/ground/rca's (and forgot to mention, do what jubella2 said)
    and you are pretty much done..
  4. jubella2
    jubella2 GC8 FTW
    just make sure to run the power and rca's down opposite sides of the car
  5. heavy hauler
    ok, i just ordered a kenwood double din stereo, front component speakers, rear speakers, and a 4 channel amp. and amp install kit.
    anyone interested in installing or lending a hand with the install when i get everything?
  6. Mr. Bill
    Mr. Bill New Member
    Dependent on when you want to do it, I would be down.
  7. heavy hauler
    ok, i was hoping you would still be interested. i don't expect to have everything by this weekend. so hopfully by the following weekend, around the 27th or 28th..
